First post, by Intel486dx33
I have several Terratec EWS88MT audio drive breakout boxes that need DB44 serial adapters.
I could not find any adapters online so I will have to make some.
It uses a DB44 male serial adapter with PCB board that connects to a 44-pin IDE cable.
I could not find this adapter online so what do you think about this adapter mod ?
I would like to use this adapter mod kit with some wires to connect the DB44 to an IDE cable
There are only 40 connections that need to be made with 40 wires going from the adapter to IDE cable.
It's not pretty but should work.
Can you think of a better way to build this adapter ?
    403.94 KiB
    Original adapter
    426.6 KiB
    Original adapter
    426.79 KiB
    Original adapter
    913.61 KiB
    1.18 MiB
Reply 1 of 8, by Intel486dx33
More photos
    522.28 KiB
    It will work like this
    89.83 KiB
    109.98 KiB
    163.08 KiB
    adapter mod kit
    365.8 KiB
    adapter mod kit
Reply 2 of 8, by Intel486dx33
IDE cable adapter for connecting wires.
    27.14 KiB
    IDE Cable adapter
Reply 3 of 8, by cyclone3d
What about using a DB44 cable and just route it back into the case from the external DB44 connection?
Or if you really want it all internal, you could just use a DB44 cable and then cut the one end off and put the needed wires in the correct place on an IDE cable end. I think that would look cleaner than the other way.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 8, by Intel486dx33
Actually, I took a closer look at the original adapter.
There are many trace connections on the PCB board to be made from DB44 to IDE.
I need to know the pin-outs for this original adapter.
    426.6 KiB
    403.94 KiB
Reply 5 of 8, by cyclone3d
Easy peasy. Just use a multimeter on the ohms setting. Then write down which pins connect to each other.
YMF7x4 Guide
Reply 7 of 8, by Intel486dx33
Okay, I took a multi-meter to the original adapter and here is the pin-out correlation from IDE ribbon to DB44 adapter.
Some of the pins have duplicate connections because the traces merge on the PCB and a few go to the same pins.
Just connect what you can and don't worry if you run out of pin connections.
Hope this helps someone who is in need of an adapter.
    341.06 KiB
    176.11 KiB
    667.83 KiB
    498.46 KiB
    124.01 KiB
Reply 8 of 8, by Intel486dx33
Can anyone help me create a PCB for this adapter ?
I have the pin-out correlation listed above.
I am trying to create a clone of the original Terratec adapter which is hard to find and can not be purchased any longer.
I created an account with easyeda.com and started the project. But I don't know how to use this application to get it to work.
https://easyeda.com
Basically, I created the schematic and added the connectors. I then tried to convert to PCB but I get an error that the connectors are not found ?
I put the project in public domain named "Terratec EWS-88MT adapter".
So I am trying to convert the schematic to PCB so I can complete the traces layout and complete this project.
Board layout = 5mm H x 6.5mm W
Connectors = "Db44 D-sub male" and "44 pin header connector".
