Can Audigy 2 zs joystick port header be used for midi and joystick in dos?
Basically I am just asking if it responds to standars joystick port/midi addresses.
chinny22 wrote:Maybe with the standard dos drivers as in theory emulating the midi port would be part of emulating a SB16. If they actually bothered when writing the driver is another question though
https://www.vogonsdrivers.com/getfile.p ... enustate=0
I WOULD think it works just fine if playing the dos game from within windows though
Baoran wrote:chinny22 wrote:Maybe with the standard dos drivers as in theory emulating the midi port would be part of emulating a SB16. If they actually bothered when writing the driver is another question though
Winrar says that archive is either unknown format or damaged.
Baoran wrote:Yeah. 7zip opened the file, but my old winrar 4.00 does not like it.
Stiletto wrote:Baoran wrote:Yeah. 7zip opened the file, but my old winrar 4.00 does not like it.
I would not say VOGONSDrivers is under any obligation to ensure the files uploaded are compatible with older utilities. WinRAR 4.00 is over seven years old. Make sure you have newer utilities available when downloading.
Users browsing this forum: dreamblaster and 1 guest
