First post, by Harry Potter
Hi! I have a Win3.1 emulation running in DOSBox, and a Win3.1 program I just installed requires SHARE.EXE to be loaded before it runs. Is SHARE available in DOSBox? If so, how do I use it?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
it's not available.
you can use fakeshare which works with win3.1 stuff, although if you need the functionality itself, you have to look at a different program.
Water flows down the stream
Reply 3 of 6, by Errius
I could not find Fakeshar when I last looked for it, but did find a similar program that does the same thing, called Noshare. I uploaded it at the end of this thread:
Help loading fakeshar.com
I successfully got Office 4.3 to run with this.
“I like to dissect PCs. Don't you know I'm utterly insane?"
Reply 4 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Fakeshar has been in the Windows 3.1x guide for a while now 😉
(Though I hope the download is still there)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
