All U.S.A 486 build advice ?
Reply 40 of 47, by Anonymous Coward
I think the Micronics boards that were commonly found in Gateway machines were all made in the USA, and they should also have Micronics chipsets which were designed and manufactured in the USA. The downside is you will be stuck with an OEM Phoenix BIOS.
Reply 41 of 47, by Intel486dx33
Ugh ! ...I have some of those micronics motherboards in Gateway 2000 486 desktop computers.
I hate that bios. I have only been able to get one to work. Those motherboards are very limited.
These VLB motherboards at least have a better bios.
Reply 42 of 47, by Anonymous Coward
There is supposed to be MR-BIOS available for those Micronics motherboards, but so far none have surfaced.
Reply 43 of 47, by derSammler
Intel486dx33 wrote:
Does anyone know of 30-pin ram made in USA ?
Not sure about SIMM modules, but I remember those "MT" dram chips, saying "Made in USA". Most unreliable DRAM ever made. 😁 Pretty sure they made SIMM modules with those, too.
Reply 44 of 47, by Intel486dx33
Okay, What would I need to do to upgrade the cache to 256kb or 512kb ?
What size cache moduals and tag would I need and how many ?
The motherboard manual list that only 128kb and 256kb are supported.
It is a 1992 bios American mega-trends Phoenix.
4GPV3 486 VESA Motherboard
- BIOS ID string X0-0100-001117-00101111-060692-CTQ596-F
- 8-30 pin SIMM slots (1-128meg FPM DRAM)
- 2-32bit VESA Local Bus slots
- 8-16bit ISA slots
- 64-256k cache support in 8-28pin sockets + 1 TAG RAM sockets
- AMI/Award/MR Bios
- CONTAQ (German) 82C596 A Chipset
- Supports the following cpu's at 25/33/40/50/66MHz
INTEL 80486SX/80486DX/80486DX2, P24C, P24T
CYRIX CX486M6, CX486M7
AMD AM486DX/DX2
- Green PC Connector
- Manufactured by: Atrend Technology Co. Ltd. or VisionEx + CTL corp. 1993
    32.35 KiB
    274.78 KiB
Reply 45 of 47, by canthearu
I very strongly recommend you do not touch the cache.
The performance difference between 256kb cache and 512kb of cache on a 486 is very small. Don't risk breaking your system by trying this upgrade.
Reply 46 of 47, by Intel486dx33
Yes, currently it only has 128kb. I would be okay with it having 256kb.
Reply 47 of 47, by Anonymous Coward
It doesn't support 512kb cache. The cache sockets are 28-pin, and to get to 512kb you need higher density modules that have 32-pins.
