Here's a link to Aztech Labs' FTP support site (it contains the drivers for most of their own Sound Galaxy range of sound cards)
The large zip file on Vogonsdrivers contains all of these drivers as well.
ftp://ftp.aztech.com/support/DOWNLOAD/sg/
However, I've attached the drivers for model I38-MMSN822. I've confirmed it works, since I have one myself.
- Filename
- Pro16II (I38-MMSN822).zip
- File size
- 2.03 MiB
- Downloads
- 70 downloads
- File comment
- Pro 16 II (I38-MMSN822)
- File license
- Fair use/fair dealing exception
I just wish to point out that this particular model (and all models based on the AZT-1605 chipset) is not Sound Blaster Pro II compatible in terms of it's DAC (i.e., digitized voice and sounds) and therefore can only generate these sounds in mono (ultimately, it is "identified" as a Sound Blaster 2.0)
It does, however, have an OPL3 FM synthesis chip. So, FM sounds can be generated in stereo, provided that the applicable application supports it.
@dionb, if you are looking for the drivers for I38-MMSN824, here they are.
These are not easy to find, since this particular model was normally bundled with OEM builders (like Packard Bell) or part of Multimedia kits.
This particular driver came from the Voyager Multimedia Kit.
- Filename
- VY212.RAR
- File size
- 2.59 MiB
- Downloads
- 69 downloads
- File comment
- I38-MMSN824
- File license
