First post, by silikone
Scouring the archived internet for an extensive amount of time, I found some programs that I have been looking for. Specifically, official applications that demonstrate the theoretical prowess of early T&L hardware. There are other old gems I have seen references to (like old NVIDIA SDKs), but never found the files for, and I believe it to be important to preserve them.
Benmark5 and learning_var are Direct3D and OpenGL programs respectively, with the latter likely only functioning on NVIDIA hardware. Both display the amount of polygons that are drawn every second, which is many millions on time-appropriate hardware. If you are curious, try them out to see your poly/s.
    BenMark5.zip
    95.03 KiB
    98 downloads
    learning_VAR_exe.zip
    114.64 KiB
    92 downloads
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
