Reply 21 of 49, by Kizmo
ph4nt0m wrote:
Seems your new VSA-100 chip has balls already, so no need to mess with a stencil. Makes it easier.
Yes, im not very big fan of reballing old crap manually 😀
3DFX - Gone but never forgotten
Reply 23 of 49, by Kizmo
Sneak peak video about todays work:
https://www.youtube.com/watch?v=YnNJn7Ebybw
And yes it does, no more green bars.
I will put together final video once i get the custom cooling solution machined. Also noticed the card is missing some decoupling capacitors around both GPUs. 10+ years in electronics scrap box did its thing, battle scars. Will repair those as well.
Reply 24 of 49, by meljor
Kizmo wrote:
Sneak peak video about todays work: […]
So you got it fixed? GREAT! Congrats!
Reply 25 of 49, by Kizmo
Yes it does run perfectly. Passed 3 hour 3dmark loop without any issues.
I keep finding battle scars such as missing capacitors. So far i have replaced 4 capacitors, all of them in GPU power plane. And all of this is because this card spent literally 10+ years in a box of misc junk with little to no protection. But it will come out good.
Reply 26 of 49, by infiniteclouds
Kizmo wrote:
If my source for VSA-100 chips turns out the be good i can offer my services for reasonable price.
In my case the damaged chip was removed with hot air but new chip will be soldered with professional rework machine ( https://www.kurtzersa.com/electronics-product … r-pl-550-1.html ). I have bad experiences trying to solder large BGA chips by handheld hot air station 😀
Nice rig. Just as a curiosity, how much do these machines cost?
Reply 27 of 49, by rasz_pl
this particular one $10-15K, Chinese ones >=$2K
Reply 28 of 49, by ph4nt0m
A $150 temperature controlled industrial heat gun will do the job just fine. You may add underside heating in case of a large GPU with lead-free balls. Something like an infrared electric cooking stove.
My Active Sales on CPU-World
Reply 29 of 49, by Kizmo
BGA reflow is somewhat simple operation but this machine does more than just heat up the solder. It has prismatic camera aided pick and place function which of course is not needed for ICs this old and large 😀 It is extremely nice to have when you work on something that has 0,3mm balls and no silk screen alignment marks. Like apple products 😁
Heat gun method sure works but having better control adds way more security and repeatability to the entire process.
And i got for almost for nothing, it was discarded from a electronics company as defective tool to be scrapped. Friend of mine rescued it from the scrap pile, repaired it and sold it tome for very reasonable price (price of repair parts)
Reply 30 of 49, by ph4nt0m
That was a bargain for sure. Although when I had to repair something with very small balls like those Volterra power chips, I just soldered them without any balls using the heat gun alone. It worked.
Reply 32 of 49, by Kizmo
Sure, i have done few in past.
But mind you i live in Finland so overseas shipping os not a viable option if you happen to live far away outside europe. PM if interested 😀
Reply 33 of 49, by Kizmo
https://www.youtube.com/watch?v=QtbNU0gHtck
So this is the end for now. Next please? 😀
Now i really have to whip up a high end PC for this card.
im not yet able to respond private messages so if you want to get in touch with me here is my e-mail address:
7.03 KiB
Reply 36 of 49, by Kizmo
dries_86 wrote:
can you fix artifacts at bios on ATI Radeon 9xxx cards ?
I might, but im not sure if its worth of doing
Arctic wrote:
Do you know how to upgrade the card to 128MB?
Yes but so far only PCI version. AGP should be doable but the layout is little bit different so it would require some reverse engineering or asking for modding schematics from somebody who has modded 5500 AGP.
Reply 37 of 49, by ph4nt0m
If it's a 9800 Pro, must be a GPU failure due to poor cooling. A simple reflow without reballing may help. If it doesn't, a GPU replacement needed which is cost prohibitive most likely.
Reply 38 of 49, by ph4nt0m
What's the point? There are numerous compatibility issues. The PCB lacks traces for the additional address strobe which has to be wired manually and that doesn't look pretty.
I can get much better performance by upgrading the memory chips from 6ns to 4ns of the same 64Mbit density.
Reply 39 of 49, by Kizmo
^ My thoughts exactly.
Large memory cards i have seen or heard of seem to be pretty difficult things to get running stable. The mod can be done with smd components, thinner green wire and no hot glue but it is still visible.
