Reply 420 of 495, by root42
Tronix wrote on 2020-09-05, 18:26:
root42 wrote on 2020-09-01, 09:25:
One thing I am wondering: was the firmware of the original SB 1.0, 1.5 or 2.0 ever dumped?
In 2019 TubeTime say in his twitter :
today i was able to confirm that i have a bit-accurate dump of the Sound Blaster CT-1351V202 DSP 2.02 firmware!
Pinging @TubeTime: is that true?
YouTube and Bonus
Reply 421 of 495, by Jager
appiah4 wrote on 2020-09-03, 09:52:
Yeah it's a 89S51.. I will look into the arduino way. Any other programmers you can recommend?
TL866. Its ability to test 74-series logic is extremely useful when assembling such cards.
Reply 422 of 495, by MJay99
Jager wrote on 2020-09-05, 20:20:
Just make sure to get the TL866II Plus - all other models are usually fakes now. The successor to the TL866II Plus was released a while ago also (XGecu T56):
http://www.xgecu.com/en/
Reply 423 of 495, by appiah4
MJay99 wrote on 2020-09-05, 21:50:
So yeah, about that.. I guess this will do?
https://tr.aliexpress.com/item/32963724045.ht … searchweb201603_
For both reprogramming the Atmel and for checking all the 74LS chips I have on the board (and in stock?)
Reply 424 of 495, by keropi
this is weird, there is the white programmer that looks like the previous ones and then there is the 125eur black one called T56
http://forums.xgecu.com/viewthread.php?tid=19&extra=page%3D1
what gives?
edit: ok the black one is the newest thing apparently they keep the 866II as a cheaper option
Reply 425 of 495, by MJay99
appiah4 wrote on 2020-09-07, 07:02:
Yeah, that should be the one. It doesn't check every Logic IC on this planet (e.g. it doesn't do the 74LS688), but it has a very good basic set.
There's a list of all currently supported ICs in their latest version:
http://www.xgecu.com/MiniPro/TL866II_List.txt
This one is for the successor device (more expensive)
http://www.xgecu.com/MiniPro/T56_List.txt
Reply 426 of 495, by MJay99
keropi wrote on 2020-09-07, 07:29:
Exactly. They actually do have quite a good english website here:
With very frequent updates in their forum (though that seems to be chinese only, but downloads are easy to find):
http://forums.xgecu.com/viewthread.php?tid=20 … =1&extra=#pid23
Reply 427 of 495, by appiah4
MJay99 wrote on 2020-09-07, 14:29:
Yeah, that should be the one. It doesn't check every Logic IC on this planet (e.g. it doesn't do the 74LS688), but it has a very […]
Ordered one of the 866II+ models, it should be good enough for 99% of what I would use it for. Let's hope it helps with my Snark Barker. At least I will know all my 74LS chips and my MCU is fine, so I can start replacing passives on the PCM circuitry one by one..
Reply 428 of 495, by Sukerbole
I'm new at this forum however I'm old.
My idea was to build a computer based on all DIY projects.
The Nuxt motherboard is ready but I ofcouse also need some sound.
Just soldered a hardmpu for midi but I'm also going to build this sb clone. My question was about the bracket.
I saw that there are some metal ones available. Could I buy one?
Reply 429 of 495, by root42
Hey, sorry. All the brackets are gone by now... but you can 3D print one.
YouTube and Bonus
Reply 431 of 495, by TubeTimeUS
root42 wrote on 2020-09-05, 18:58:
Yeah I was able to dump it. It was an enormous pain in the butt. 😂
But the firmware in the repo is not that dump.
Reply 432 of 495, by Tronix
The Сreative Labs CEO said in an interview :
CPC: Some hobbyists have found ways to clone old ISA Sound Blaster cards, ordering a pre-made PCB and soldering in the components (such as the Snark Barker in the video below). Given that Creative hasn’t made these cards for 25-odd years, do they have Creative’s blessing?
Sim Wong Hoo: We have no issues with individual hobbyists who are nostalgic about our very old Sound Blaster cards.
As far as I understand, nothing prevents from uploading SB 2.0 dump -)
https://github.com/Tronix286/
Reply 433 of 495, by Thermalwrong
TubeTimeUS wrote on 2020-09-23, 02:15:
There are some clues looking at the file in a hex editor 😜 How close is the clone to the real deal in terms of function? I've been wondering if it just matches it in functionality or if it's a direct clone apart from some identifiers.
Sukerbole wrote on 2020-09-22, 20:38:
Ok thanks for the reply. Is that strong enough in such a thin wall thickness? It’s like 50 - 100 times less stiff.
It's strong enough with good quality PLA. I upped the thickness of the bracket slightly to compensate and the print direction is picked so that it's rigid and unlikely to break at the angled part of the bracket.
It might be too flexible with a filament like PETG at this thickness though.
Reply 434 of 495, by TubeTimeUS
Thermalwrong wrote on 2020-09-23, 18:57:
It is very close in functionality but the code is quite different.
Reply 435 of 495, by Thermalwrong
Thanks for confirming, I suspected that was the case. Both my Snark Barker and real SB 2.0 clone (same firmware) work fine in my experience so I've no issue with that. Also thanks for the presentation on what was involved with making the card and checking that firmware, it was quite an adventure overall 😀
Reply 436 of 495, by Cyrix200+
The Snark Barker MCA is coming along nicely, TubeTime's Twitter thread shows the process 😀 : https://twitter.com/TubeTimeUS/status/1299181646755708928
1982 to 2001
Reply 437 of 495, by appiah4
Hello guys, it's me again, miss me? 😁
I have a new toy, the TL866II Pro programmer, so I thought I would start checking every IC on my Snark Barker's hosed digital audio circuitry, starting from the DMA all the way up to the audio out. I didn't get very far before I tested the DSP and got this:
14.09 KiB
No amount of removing and resocketing the DSP chip fixes the bad pin error. That is Pin 7, i.e. DAC6 line. I suppose I probably found the culprit?
Locally ordered a cheap DIP-40 89S51 (Apparently used, but OK..)
Reply 438 of 495, by root42
Congratulation and condolences... I hope you found the culprit for real this time. That was the chip I programmed for you, right? I hope it didn't get damaged in shipping! It was a new item from Mouser, and it's two brothers are working fine in my own SnarkBarkers. I hope the replacement will work!
YouTube and Bonus
Reply 439 of 495, by appiah4
root42 wrote on 2020-10-26, 13:27:
Indeed it was, but to be fair I kept it in storage for over a year before I got to work on this project so I can't know if the damage happened in transit or in storage. Regardless, it doesn't matter. All it matters is that I want to get this card to work.
By this point I've invested more in ICs and tools to troubleshoot the problems that what it would cost to buy three seperate SB 1.5s online 🤣
