First post, by mkubiak402
i have an FIC PA-2005 with 256k of L2 cashe and it is not being detected might it just be bad cash chips or a bad tag? i have a donor board and was thinking of swapping the cashe and tag over?
DOS 6.22 FIC-486-VIP-IO AM486-DX2 66Mhz 64mg
Win98se MS-5169 AMD K6-III+ 450 @ 550Mhz 512mg Voodoo 5 5500.
Win98se GA-6VXE7+ Intel Pentium III 750 512mg Voodoo 5 5500.
Win XP MS-6712 AMD Athlon Xp 2700+ 2gb 6600GT
Reply 1 of 8, by dionb
Soldering over surface-mount PLB cache is pretty challenging soldering work. If you're confident of your ability, you can try, but I'd recommend ruling out other options first.
- not aware of any cache <> BIOS issues on the PA-2005, but checking if there's a BIOS update is always a good idea.
- bad cache chips usually show up as memory errors, not appearing at all would make me suspect the control/power circuitry around the cache, or some damaged traces. The power cable is a bit in the way in your photo, but above the "V" of "300V" on the cable looks like it could be some pretty severe damage to the board (that white blob). Also don't entirely trust CT38
Reply 2 of 8, by mkubiak402
the Cap on CT38 looks fine.
the new BIOS
619j900.zip
1.3/1.31 AWARD BIOS ver. 619J900 08/21/97
1. Fix system boot-up failure when using K6 CPU with 586_3028D.
2. Added new parting table for 6x86MX CPU.
3. Fixed system hang-up while starting Win95 with MACFEE Virus-scan application.
4. Use Flash534.zip for flashing!
the one that's in there now looks to be the BIOS ver. 616J900 04/11/97 so it's a few Revs older
Here is a pic with out the power cable in the way
Reply 3 of 8, by mkubiak402
update: got the new BIOS 6.19J900 installed same deal no L2 cashe
Reply 4 of 8, by mkubiak402
i all so made sure and there is 3.3v going to the chips
Reply 5 of 8, by ajs83
mkubiak402 wrote:
the Cap on CT38 looks fine. […]
the new BIOS
619j900.zip
Hey i know it is a little old but still... does anybody know how or were to get the bios of this board?
My bios chis is showing a very old version and i want to install a bigger disk (now i can not go beyond 8Gb and i would love to have 20 or 32Gb in there.
I found a hacked bios that supports up to 128Gb but this one i could not installed mismatch of my machine....
Anyone know if there is a official bios somewere, al links to the fic ftp are broken...
1.95 MiB
Bios chip
1.95 MiB
Bios chip
    1.67 MiB
    BiosScreen
Reply 6 of 8, by mkubiak402
i did see my motherboard listed on some webpage and i had the newest bios but you need to know what Ver of the board you have.. ill see what i can come up with..
Reply 7 of 8, by mkubiak402
ftp://ftp.fic.com.tw/motherboard/bios/socket7/pa-2005/
Reply 8 of 8, by Doornkaat
ajs83 wrote:
Hey i know it is a little old but still... does anybody know how or were to get the bios of this board? My bios chis is showing […]
Have you tried Uniflash to flash your BIOS in real DOS?
Also peel off the label on the BIOS EEPROM and check what type of EEPROM it is. The jumper next to it is to set the EEPROM type.
Refer to http://pcrebuilding.altervista.org/9/download … c_mb_pa2005.pdf page 16 (PDF page 22) for configuration details.
Good luck! 😀
