Reply 20 of 105, by Intel486dx33
This computer plays CDROM's with .WAV files fine, but not MP3's ?
Is the CPU not powerful enough to play MP3's ? I am using winamp MP3 player and Win95c.
I can always connect a Bluetooth adapter to the Audio input on the sound card and stream music with my iPad.
Reply 21 of 105, by gdjacobs
I've heard of it being done with decoders that can squeeze out every cycle. Maybe with MPXPlay or even DOSAMP/DAMP. A 486 is probably too slow for Winamp.
http://forums.winamp.com/showthread.php?t=32671
Reply 22 of 105, by cyclone3d
Not sure if your CPU is going to be able to handle MP3 decoding unless you have a hardware decoder as is mentioned in this thread:
MP3 hardware decoding ISA cards
Good luck finding one.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23 of 105, by cyclone3d
Here is a bit more information.. and it looks like you want something faster than a Pentium 75Mhz to be able to play high bitrate MP3 properly... but I guess some more optimized players might be able to do it with a slower system.
http://www.vcfed.org/forum/archive/index.php/t-22777.html
You could always design and build an MP3 decoder card yourself using the STA013 MP3 Decoder Chip.
https://www.pjrc.com/mp3/sta013.html
YMF7x4 Guide
Reply 24 of 105, by keenmaster486
keenmaster486 wrote:
Try using IE 3 or Netscape 3.04 for fast browsing in 95! I’ve been experimenting with those over the past week.
Why did I say this? Did I have a reason to say this? Reading through this thread I can't find why this would have come to mind. I am confusion.
World's foremost 486 enjoyer.
Reply 25 of 105, by Intel486dx33
Is there a internet portal or webpage with links to browser friendly websites ?
Reply 26 of 105, by keenmaster486
Portal or webpage friendly to old web browsers ?
Reply 28 of 105, by Intel486dx33
This computer works great. But the video card is going out. So I am going to try a Number nine S3 vision 968 PCI card.
But the Media Vision PAS16P sounds great.
Which is what I really built this computer for.
Reply 29 of 105, by Intel486dx33
DOOM game test results.
Gametics=2134
Realtics=1894
Reply 30 of 105, by Intel486dx33
I purchased some Advent desktop speakers from 1995 and they sound great. I think I can add an Advent subwoofer to these.
    87.38 KiB
    412.52 KiB
    208.16 KiB
    228.6 KiB
    415.42 KiB
Reply 31 of 105, by Intel486dx33
I really like this computer setup.
I wish I had it back in 1995.
The Advent Speakers sound awsome with the Media Vision Spectrum Pro Audio PAS16P.
It's a nice clean White computer too.
Very stable. No problems so far. No crashes.
Surfs MSN.com very good.
Vogons.org however is slow to load.
I am posting right now from this computer.
The Compact Flash card really makes a difference.
Performace is much improved with IDE CF card.
I replaced the floppy drive with a white one so the computer is all white now. runs fairly quite too.
I can play a music CD and surf the internet at the same time.
I am running Win95b, I.E. 5.50.4 ,and Win95 updates and I.E. tweeks.
Reply 32 of 105, by Intel486dx33
I purchased another CPU Incase this one burns out.
Reply 33 of 105, by feipoa
An Am5x86 at 160 MHz should be able to play 128 kbps, stereo, 44khz mp3 files without skipping or downscaling. I don't recall if 192 kbps mp3s play, but I can check. What is the sample rate of the mp3s that you are playing?
Could you share the speedsys graph of your system? I have an m918 and its L2 cache performance was horrific. Perhaps this is related to your mp3 issue.
Nice looking case with a 2+1 display. Are there more of these from where ever you found it?
Reply 34 of 105, by Intel486dx33
Here is my benchmark info here:
The Ultimate 486 Benchmark Comparison
I am trying to play MP3’s with Winamp.
This computer was a Barn find. The case was not in to bad of shape. But not great.
I do see one on sale on eBay. But it’s a desktop model.
https://www.ebay.com/itm/MT-747E-AT-Style-Des … FgAAOSwxJ9cPNeH
Reply 35 of 105, by feipoa
mp3's have many different possible sample rates for playback; the higher the sample rate, the more CPU intensive it is. What sample rate mp3s are you trying to play?
I could not locate a Speedsys screenshot in that link. Could you paste it here?
Reply 36 of 105, by Intel486dx33
Here is a speed test benchmark.
Reply 37 of 105, by feipoa
Speedsys looks like this:
12.96 KiB
I'm wanting to see the plot of your cache and RAM.
Reply 38 of 105, by Intel486dx33
I had put the cpu back to 133mhz. Because i did not see any benefit at 166mhz.
As you can see from speedsys test results my L1 and L2 cache scores are low ?
Here is my bios settings too.
They are 192 kbps mp3s, 44khz.
Reply 39 of 105, by feipoa
Interesting that there isn't a read speed decrease for main memory. I experienced something similar to this on my m918 as well. I'll plug in my Am5x86-160 system to see if it can decode 192 kbps mp3.
There is little concern about damaging an Am5x86 at 160 MHz.
