Reply 41 of 105, by feipoa
I can only find 128 kbps, 160 kbps, 320 kbps, and variable. I don't appear to have any 192 kbps mp3s.
Reply 42 of 105, by feipoa
Well, not even the 320 kbps mp3 has skipping in it on my Am5x86-160. I am using Winamp 2.05 with the Nullsoft wave-out 1.0. I have turned the spectrum analyser off and have turned off auto scrolling the song name. Those help cut down on CPU load. The scrolling song name is a bit demanding.
Reply 43 of 105, by feipoa
Attached is what Speedsys looks like on my Am5x86-160 system.
Are you able to upload Speedsys for your system at 160 MHz?
12.96 KiB
Reply 44 of 105, by Intel486dx33
Okay, I bumped it back up to 3.3v.@160mhz.
I still get the skipping and studdering in MP3 playback.
I read the manual and it reads I need a 12/12/95 bios or better to support the AMD 5x86@133.
I only have bios 10/10/94.
Any idea where I can get a bios update ?
My memory and cache scores are really low compared to yours.
You have a much newer bios in 11/19/97
Reply 45 of 105, by feipoa
look at 9181230.rom in this package. Not sure what the date is, but the BIOS has a mod date of 30/12/1996.
Reply 47 of 105, by feipoa
In general, I was rather unimpressed with the PC Chips M918. It might be of benefit to try some other motherboard's BIOS on this board, provided it is the same chipset. On my list is to try the Gigabyte GA-5486AL BIOS on the M918 in hope for some speed benefit.
Reply 48 of 105, by Intel486dx33
I need an Amibios DOS flash unity that will work with this ROM files.
I get an error trying to flash this bios.
Reply 49 of 105, by feipoa
I don't know - I always use an external programmer. If you don't have or don't plan to buy one, try uniflash.
Reply 50 of 105, by Intel486dx33
Okay, Since I can't flash the bios right now maybe the bios settings for cache and timing is wrong.
Since this CPU is not supported by default and auto settings in bios.
I will need to set the cache and timings settings manually.
Do you happen to know the best settings for this CPU ?
AMD 5x86-133-P75 over clocked at 4x40mhz. = 160mhz.
Reply 51 of 105, by Intel486dx33
Okay, I changed the bios timing setting and ram and cache scores did improve a little.
I was using 5 and 4-1-1-1 for timings.
I am now using 4 and 3-1-1-1
Let me try an older Winamp version. ( v2.1 ).
I think the current version I am using( v2.7) maybe causing the problems.
Reply 52 of 105, by Intel486dx33
Okay, I found the best bios settings for this CPU.
Let me do some benchmarking and regression testing to confirm it’s stable.
Reply 54 of 105, by Intel486dx33
Okay, I am using
Clk/5
Timing = 3-1-1-1
WS=0
In DOS 2.66 I ran all the benchmark tests on Philscomputerlab Benchmark CD and the computer is very stable. No problems.
I think I am going to reinstall Win95c because it is not running right.
Other than that the computer is rock solid stable.
Lucky with the hardware I selected all the drivers are included in Win95c.
So reinstallation is a breeze. Plug and Play.
Reply 56 of 105, by feipoa
lol
Reply 57 of 105, by treeman
hahayeah and I think I might try a riva tnt2 pci on my x5 and see if I can squeeze a few more pips of a fps in quake which is no way period correct but why not if he gets to reinstall win95... C
Reply 58 of 105, by feipoa
I recall the TNT2 being problematic on 486 boards, but the original TNT should work with an Am5x86.
