Needed support for ATAPI IDE CD-ROM drive
General information and assistance with DOSBox.
Postby misa » 2019-2-08 @ 16:05
My application (the Academic American encyclopedia) needs to combine sounds comming directly from the CD-ROM drive (by the headphones inserted into 3.5 mm socket on its front panel) with the text of some its articles. Otherwise an application dependent error occurs. How to avoid it in DOSBox? Thank you.
misa
Re: Needed support for ATAPI IDE CD-ROM drive
Postby collector » 2019-2-09 @ 02:16
Make an image of your CD and mount it?
User avatar
collector
Postby _Rob » 2019-2-14 @ 08:00
There are two common ways to get a CD image.
    - ISO, but this is only useful for pure single-track DATA CD's using the ISO9660 format.
    - CUE/BIN format. This format allows you to capture all tracks, data or redbook audio.
So in your case, just look for a CUE/BIN ripper program for the OS your running. Then in DOSBox select to mount the CUE file.
_Rob
Return to DOSBox General
Who is online
Users browsing this forum: knowledge [bot] and 0 guests
