Strange 386 motherboard
Reply 20 of 28, by eisapc
n0m4d wrote:
The memory expansion fits perfect to my motherboard, sadly it not working. Without ram motherboard can't wake up, its beeping, without ram, but with memory expansion nothing, MB can't boot, with ram and expansion its starting but its freezing during memory count.
It may need the correct switch or jumper settings to make use of the memory board? Whats making the board rare is more the TI chipset and these strange square cache chips than the cache controller. Never seen both before. These proprietary memory slots were quite common on early 386 boards.
eisapc
Reply 22 of 28, by Predator99
There are no jumpers on the card itself?
I would try to remove the whole memory from the memory card. Does it boot with an empty expansion card?
If yes, populate only one bank at the end and try this program/procedure:
ISA XMS/EMS Memory Extension / Expansion cards: Now Running without Driver / Documentation :-)
Reply 24 of 28, by n0m4d
which one is a bios chip? I want to sent it to copy my bios but I'm not sure which one
    1.9 MiB
Reply 27 of 28, by tayyare
n0m4d wrote:
And chip on left side? Its also bios?
It's a keyboard controller chip.
https://en.wikipedia.org/wiki/Keyboard_ ... computing)
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 28 of 28, by root42
Which also contains a bit of code, since it's a microcontroller. See here:
https://en.m.wikipedia.org/wiki/Intel_MCS-48
That's probably why it has a copyright sticker by Phoenix on it.
YouTube and Bonus
