Reply 20 of 63, by thepirategamerboy12
Totos82 wrote:
Pleasepleasepleaseplease i need bios file Ga.04.02 please you are my last hope!
I'll dump the BIOS next time I use the machine. Sorry I haven't replied until now. Haven't logged into Vogons for a little while.
Reply 21 of 63, by thepirategamerboy12
Okay, I finally replaced the battery. It actually uses a BR2325 battery, but I used a CR2032 and it seems to save settings now. Still having the hard drive issue, however...
Reply 22 of 63, by Deksor
What kind of HDD is in there ? Is it a quantum ?
Have you checked if the IDE cable is ok or not ?
You could also run memtest86
Have you been in the bios setup and used the "reset to setup default" ? Sometimes some values you don't see are not in the correct state and can only be set properly this way
alternative
Reply 23 of 63, by thepirategamerboy12
I'll do all that very soon because suddenly the computer is now extremely temperamental about even booting up... It often just keeps detecting the drive as 0MB.
Fyi, I'm almost certain the drive itself is good.
Reply 25 of 63, by thepirategamerboy12
So, I swapped IDE cables and it didn't help at all. In fact, for whatever reason the machine is running a lot slower than before. The post beep is noticeably longer... Also, Memtest86 just makes the computer reset as soon as it starts to test the memory.
Reply 26 of 63, by yawetaG
Well, clearly then there's more wrong with that machine than just weird hard disk behaviour. Memtest86 is a tried and tested memory testing program, so if it causes your system to reset...
Try replacing the RAM by known good modules, or put the current modules in another machine and run Memtest86 on that system - If the modules also give problems on another system, replace them.
Reply 27 of 63, by thepirategamerboy12
What's odd, though, is that Memtest86 also does the same thing in an emulator (PCem)...
I had an older version of Memtest86 I know worked without problems on older hardware. I'll have to try and find it.
EDIT: Just looked it up and someone else on Vogons had the same problem with running Memtest on a 486.
Reply 28 of 63, by Deksor
Yeah you need an old version, I have the same issue on my 486s. Somebody should test which is the last version of memtest86 that works on 386-486s I think
alternative
Reply 29 of 63, by thepirategamerboy12
I tried Memtest86+ 4.0 and that worked fine. No RAM errors detected. Other than the hard drive issue, though, I don't get why it's seemingly running slower than before. Did I somehow mess up a jumper?
Reply 30 of 63, by Deksor
Since you've replaced the CMOS battery, have you selected "reset to bios defaults" in the bios or something like that ? Maybe cache is now disabled in the bios ?
alternative
Reply 31 of 63, by thepirategamerboy12
Perhaps that's what it is, yeah. All these worse problems occurred when I changed the battery. Come to think of it, in Memtest L1 ad L2 cache came up as "unknown." I don't remember seeing a default settings option in the BIOS, though, but we'll see when I get back to it later tonight.
Reply 36 of 63, by thepirategamerboy12
So no, the 40GB Western Digital drive will not work with this machine. It shows up as an 8GB drive, as expected, but since no HDD will work in auto detect mode, I have to put everything in custom, and it won't actually let me put any number of heads higher than 127 myself (it needs to be 255). When I settle for that, the drive shows up as C: and can be formatted, but no data can be written.
Btw, I'm sure the 1.2GB drive isn't the problem because I said before it works fine on my other computers.
Reply 37 of 63, by Totos82
Thank you so much!! Ill wait...
Reply 38 of 63, by Deksor
That computer probably doesn't support LBA. Have you tried Ontrack disk manager ?
alternative
Reply 39 of 63, by Murugan
Yup, give Ontrack a try or EZ-drive.
