Sound Blaster Audigy 2 for in windows98 dos prompt
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby MKT_Gundam » 2019-2-12 @ 01:45
For Dos games (in win98se) for sfx + general midi, the Audigy 2 is Okay?
Also this soundcard feature options to load custom/ bigger soundfonts like the live cards?
User avatar
MKT_Gundam
Re: Sound Blaster Audigy 2 for in windows98 dos prompt
Postby doaks80 » 2019-2-12 @ 02:15
No, get an Audigy1 or Live.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
doaks80
Postby MKT_Gundam » 2019-2-12 @ 02:22
doaks80 wrote:No, get an Audigy1 or Live.
I got the Audigy 2 + front panel 5.25 for few bucks.
Is the front panel compatible with a live card? Mine is 4760 ( gold plated one)
I would use this card on bx board + Sb32 or a audician32.
User avatar
MKT_Gundam
Postby doaks80 » 2019-2-12 @ 02:36
If you want to play DOS games, and have an ISA slot+audician32....go with that option. The XG softsynth in Win98 is actually quite good. Keep/combine the Audigy2 for pure windows games.
Personally I combine an Audigy1+AWE64 on my Win98 rig.
doaks80
Postby MKT_Gundam » 2019-2-12 @ 03:11
doaks80 wrote:If you want to play DOS games, and have an ISA slot+audician32....go with that option. The XG softsynth in Win98 is actually quite good. Keep/combine the Audigy2 for pure windows games.
The Audigy 1 feature the custom soundfont like the live?
User avatar
MKT_Gundam
Postby doaks80 » 2019-2-12 @ 03:54
The Audigy1 is basically just a better Live, that does everything the Live does including DOS compat. But if you are using the audician for DOS, the Audigy2 makes an excellent Win98 card, if not the best of all.
doaks80
Postby PARUS » 2019-2-12 @ 09:09
Yes. The Windows 98 DOS prompt support is disabled in Audigy 2 driver.
MKT_Gundam wrote:Is the front panel compatible with a live card? Mine is 4760 ( gold plated one)
No, it is not. Live model doesn't matter, they all (Live+Audigy1) have identical 40-pin pinouts. All Live/Audigy1 front panels are compatible with each other and have a same pinouts. The Audigy2 front panels are different compared to Live/Audigy1 and aren't compatible, have another pinout scheme. By the way X-Fi has identical compatible pinout to Audigy2.
MKT_Gundam wrote:The Audigy 1 feature the custom soundfont like the live?
Yes. And Audigy2 also.
doaks80 wrote:The Audigy1 is basically just a better Live, that does everything the Live does including DOS compat.
No, it isn't. Audigy1 is totally newer DSP compared to Live. With hardware EAX3 support. And yes, it does everything the Live does including DOS.
doaks80 wrote:But if you are using the audician for DOS, the Audigy2 makes an excellent Win98 card, if not the best of all.
For Windows XP - probably, yes. For Windows 98/ME - rather no.
Audigy 1 has hardware EAX3, 5.1 sound, DD decoding, SB16 Emulation
Audigy 2 has hardware EAX3, 6.1 sound, P16V DVD Audio, DD decoding
Audigy 2ZS has hardware EAX3, software EAX4 (via driver), 7.1 sound, P16V DVD Audio, DD decoding, DTS ES decoding, ASIO2
You may use Audigy 2/2ZS advantages in Windows XP but not in Windows 98 :) In Win98 all three Audigys are the same on practice.
User avatar
PARUS
Postby MKT_Gundam » 2019-2-12 @ 10:01
I just cheked a older thread and for pure DOS has a patch to use the Audigy 1 driver: viewtopic.php?f=46&t=43092
Also this guy use one in pure DOS: https://www.youtube.com/watch?v=261nKIdJhKw
User avatar
MKT_Gundam
Postby Justin1091 » 2019-2-12 @ 11:50
Yeah I use my Audigy 2ZS in DOS and Win98 dos prompt, works fine with the patch. For Win98 Dos prompt you need to do this though:
When using the WDM drivers, Windows itself will emulate a Sound Blaster Pro. Nothing needs to be done and nothing special will show up in Device Manager.
SB16 emulation requires the .vxd driver set. Additionally, a change to the registry is needed and the driver needs to be installed twice.
The Creative inf files do not install SB16.inf and can’t correctly install it by any method until you add an entry to the registry.
REGEDIT4
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\CreativeTech\Emu10kx\Emulation]
"EnableSB16Emulation"=dword:00000001
You can either create an SB16.reg with the above lines and double click on it, or manually add the entry to the registry. Once this is done and you reboot, the system will try to install SB16 emulation from the SB16.inf. Typically installation will fail and you will see a yellow ! with Device Manager. Don’t worry, just go to Control panel / Add New Hardware and reinstall the emulation. When using Add New Hardware, make sure to select manually from a list of Sound Devices / Creative Technology LTD the SB16 emulation drive with the most recent date if more than one is present. After a reboot, a second entry will appear in Device Manager for emulation, it will work, and you should ignore the original non-functional entry still present.
I don't remember who wrote that, but it was on Vogons I think. Credits and thanks to whoever wrote it as it works perfectly!
Justin1091
Postby PARUS » 2019-2-12 @ 18:31
MKT_Gundam, yes, I'd use this Audigy12.exe patch for Audigy2 in 2006. Audigy1 doesn't need this patch.
Justin1091, thank you very much!!! I always knew that Creative have drop DOS support on Audigy2. And I always knew that A1 and A2 DSPs are almost the same expect P16V unit on A2 DSP, I knew about A2 pure DOS patch. But I never knew that easy way exists to enable SB16 in Windows.
Thank you again.
User avatar
PARUS
Postby MKT_Gundam » 2019-2-13 @ 00:32
Justin1091 wrote:When using the WDM drivers, Windows itself will emulate a Sound Blaster Pro. Nothing needs to be done and nothing special will show up in Device Manager.
The MIDI sound will be the windows roland one just like some AC97 onboard cards? Still the loading soundfont working?
User avatar
MKT_Gundam
Postby PARUS » 2019-2-14 @ 07:49
MKT_Gundam, WDM driver is not a good choice for Win9X especially if you want to play "hard" quick machine demanding games. Choose VxD and leave WDM for WinXP.
User avatar
PARUS
Postby The Serpent Rider » 2019-2-14 @ 17:18
EAX 4.0 is still technically in hardware, because it was released with ZS series. But it's more or less just refined EAX Advanced HD which was limited to ZS/4 Pro due to obvious marketing reasons.
User avatar
The Serpent Rider
Postby PARUS » 2019-2-15 @ 05:10
It was released with ZS, yes. But now update for enable EAX Advanced HD exists for both series, A2 and A2ZS. It's the same update for both cards and therefore we can say that hardware availabilities of A2 and A2ZS are identical. About EAX4 (Advanced HD) we don't know strongly if it's hardware or software realization. But in any case as I said in Win98 we can't feel different if use A1, A2 or A2ZS. Just 9X-era games don't utilise A2 features.
User avatar
PARUS
Return to Sound
Who is online
Users browsing this forum: Sanders and 3 guests
