This Program cannot be run in dos mode
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby vish2648 » 2019-2-13 @ 04:15
Hello,
I am trying to interface microprocessor to display "FIRE" on seven segment through MASM. In order to establish communication from PC, I am using AllowIo.exe to establish communication. I have used the following command
-- AllowIo 0xd800 FIRE.EXE
If I execute the following command I am getting the error "This Program cannot be run in dos mode"
vish2648
Re: This Program cannot be run in dos mode
Postby keenmaster486 » 2019-2-13 @ 04:19
Gee whiz, what do you suppose that means?
I flermmed the plootash just like you asked.
Very silly indeed: https://audaxeundum.wordpress.com
User avatar
keenmaster486
Postby realnc » 2019-2-14 @ 22:02
That's the error message you get when you try to run a Windows program in DOS.
User avatar
realnc
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 0 guests
