Problems with Media Vision PAS16P
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby Intel486dx33 » 2019-2-13 @ 16:35
I don't know what is wrong.
It was working fine before.
New install of Win98se.
I have a Media Vision Spectrum Pro Audio PAS16P
Used Win98se default Media Vision drivers which usually work fine.
Device manager show PAS16 is working fine.
What is happening:
When the PAS16 play audio it plays with a high tone and plays really fast.
Does anyone know what is wrong ?
User avatar
Intel486dx33
Re: Problems with Media Vision PAS16P
Postby bristlehog » 2019-2-13 @ 18:39
Your PSU lacks -5v rail. This soundcard needs it to operate properly.
User avatar
bristlehog
Postby Intel486dx33 » 2019-2-13 @ 19:44
Is it the Power supply that's the problem or motherboard not supplying 5v to the ISA slots ?
I am using a 500 ATX PSU.
User avatar
Intel486dx33
Postby Tenorman » 2019-2-13 @ 19:48
This is an interesting card. I've never seen a PAS16P that is missing the LMSI connector and controller chip before. Almost like a PAS16LL.
I agree that the -5v rail is the likely issue, but these cards are also speed sensitive and will have problems if you are trying to use them in anything faster than an original Pentium.
[Compaq Presario 633 | DOS 6.22 / Win 3.1 | DX4 100 Overdrive | 28M RAM | SB16 CT2770A | SPEA Media FX (Soundscape S2000) ]
[GA-6BXC R2.0 | Win98SE | Via C3 Ezra 866 | 384M RAM | TNT2 M64 16M | Voodoo2 8M | SB 32 CT3670 | Ensoniq Soundscape Opus]
User avatar
Tenorman
Postby Intel486dx33 » 2019-2-13 @ 20:15
Yeah, It worked fine in my AMD 5x86-P75 over clocked at 160mhz.
Running Win95c with Vanilla drivers.
User avatar
Intel486dx33
Postby cyclone3d » 2019-2-13 @ 21:53
Intel486dx33 wrote:Is it the Power supply that's the problem or motherboard not supplying 5v to the ISA slots ?
If it is the fact that the power supply doesn't have a -5v (negative 5 volt) output, you can get an adapter on eBay that adds the -5v.
https://www.ebay.com/itm/NEW-6-ATX-24PIN-NEW-NO-5V-TO-OLD-20-PIN-W-5V-PWR-CONVERTER-MADE-IN-USA/251854771572
And it could be speed related as well.
User avatar
cyclone3d
Postby Intel486dx33 » 2019-2-14 @ 02:50
Yes, I put the PAS16 back in my AMD 5x86-P75 Overclocked @ 160mhz. computer and it works great with an AT power supply.
I really like the sound of the PAS16P
Running Win95c with Vanilla Media Vision drivers.
PCchips M918i motherboard.
User avatar
Intel486dx33
Postby bristlehog » 2019-2-15 @ 06:57
bristlehog wrote:Your PSU lacks -5v rail. This soundcard needs it to operate properly.
May be either or both issues. You have to read your PSU and motherboard specs.
User avatar
bristlehog
Return to Sound
Who is online
Users browsing this forum: No registered users and 2 guests
