Detect best cycles/match recommended specs?
General information and assistance with DOSBox.
Postby Myg » 2019-3-13 @ 23:30
Is it possible to detect the most effective cycles for a game? Is it also possible to emulate the recommended specs for a game with the cycles in the config file (what is the conversion rate cycles to mhz)?
I ask because games like mechwarrior 2 don't function properly (100%) even with the auto setting (jumpjets won't recharge).
Myg
Re: Detect best cycles/match recommended specs?
Postby Roger Wilco » 2019-3-15 @ 15:36
There is a benchmark program that allows you to see the emulated CPU speed in realtime.
http://www.oldskool.org/pc/benchmark
But I can't tell about the accuracy, maybe other benchmark programs are suited better for Dosbox.
User avatar
Roger Wilco
Postby Myg » 2019-3-17 @ 18:29
Download didn't work.
Anyone else have any ideas/etc?
Myg
Postby krcroft » 2019-3-17 @ 20:16
Myg wrote:Download didn't work.
I manually adjust cycles to find the minimum amount where no further improvement in playability or visual smoothness can be seen. I then record it as part of the games' startup config. I've done this for about 560 games in my library; happy to run a dump for you.
User avatar
krcroft
Postby Myg » 2019-3-17 @ 22:08
Yea, thats what I do as well: I was hoping for an easier way.
Does anyone know the conversion rate between cycles and cpu mhz or does it not work like that?
Myg
Postby Roger Wilco » 2019-3-17 @ 22:26
Attached:
The Oldskool PC Benchmark
Version 0.38a, 20140328
topbench.zip
(101.33 KiB) Downloaded 3 times
User avatar
Roger Wilco
Postby krcroft » 2019-3-17 @ 23:01
Emulated CPU, Cycles
8088 4.77 MHz, 315
286 12.5 MHz, 2750
386 33 MHz, 7800
486 66 MHz, 26800
Pentium 100, 77000
Pentium II 300, 200000
From https://www.dosbox.com/wiki/Performance
User avatar
krcroft
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 4 guests
