First post, by wtatarek
Hello,
I can't bring my mouse to life. The MOBO has onboard serial controller. I was trying to turn it off and put external controller card (which works perfectly with the same mouse on other system) but nothing changed... I use ctmouse.exe and mouse.com driver.
The board has a PS/2 connector too and it works with other mices. But I want to know what's the issue with serial port (if it is).
This is the last thing I have to complete to finish my perfect 486 computer.
Kindly regards,
Wiktor
Reply 1 of 3, by ZipoBibrok
I had similar problem. The board needs serial port bracket with staggered pinout, even though the manual lists the pinout as sequential.
Reply 2 of 3, by Windows9566
i had that same issue earlier with my asus vx97, i eventually got it working after i found some serial brackets at the thrift store.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 3 of 3, by SSTV2
Check +12/-12V lines directly in ISA slot. If serial ports are detected, but mouse isn't (even by trying different I/O cards) most likely one of the 12V lines are absent due to corrosion on motherboard's power header or PSU sockets.
