Upgrade from 386 to 586?
First post, by uscleo
Hi Guys,
I just came across a CPU upgrade for a 386 to 486 (Make it 486 from Make It Technologies) - its a PGA-132 socket with a board in-between with a few ICs on it and a TI 486 SXL2-50 (PGA168) on top.
I was wondering since this is a "real" 486, would it be possible to replace the TI 486 SXL2-50 (I don't have it in hand yet so I would either desolder or hopefully it's just in a socket) and replace it with a 486 to 586 upgrade such as AMD 486 dx5 (the same chip used in the Kingston 486 to "586" upgrades) to get even more speed 😎
I found this old thread below that makes it seem like it's possible, but I was wondering if anyone had any experience, pointers or what to watch out for etc.
http://www.vcfed.org/forum/archive/index.php/t-57033.html
What do you guys think?
Reply 1 of 46, by Anonymous Coward
It's not quite a real 486. The socket will not be compatible with standard 486 chips.
There are socket adapters that do what you want, but this isn't one of them. I have one (Transcomputer 486HPi) that does indeed let you use 5x86 chips on a 386 board.
Reply 2 of 46, by uscleo
Ah, ok, well it's good to have on hand anyway... what about this one? I also have one of these. Will this work as it has a real 486 (though it is an SX)
http://ohlandl.ipv7.net/CPU/Kingston_486-Now.html
Reply 3 of 46, by uscleo
Got some time to plug it in to my compaq 386 and run a few benchmarks. Anyone any idea if the 486 can be replaced using this board?
Reply 4 of 46, by LeFlash
What's under that Kingston sticker?
It's irritating that one benchmark tells you it's an 486DX, but there's clearly an SX on the PCB.
Maybe there's a DX soldered next to it?
The problem here is that your CPU is 5V. To get, f.e. an DX4 running, you'll need a 3.3V regulator board inbetween.
After that - theoretically - you shall also be able to run a 5x86 and other fast CPUs!
Reply 6 of 46, by LeFlash
Indeed. I wonder what that big IC with the kingston label really is!
The GALs shall be readable in theory and a clone of this board would be awesome
Reply 7 of 46, by Anonymous Coward
I am pretty sure the answer is yes. A 5x86 should work in that Kingston upgrade provided you have a VRM.
Reply 8 of 46, by uscleo
Thanks for the responses guys. My soldering / desoldering skills are decent, but I don't really want to have to unsolder 168 pins.
Does anyone know of a trustworthy & professional soldering / desoldering service? I'm planning to add a PGA168 socket onto the board so I can test out different PGA168 CPUs.
Reply 9 of 46, by LeFlash
The 486 is already socketed. Just lift it carefully
Reply 10 of 46, by uscleo
Really?? I don’t think so. There isn’t a socket, the pins from the cpu do extend into the pcb, as you can see in the pics. I think the tips of the pins are soldered to the silver “pin holder” on the other side if that makes sense
Reply 11 of 46, by kixs
To me it also looks like it's socketed. Not in the usual way. But try lift it up a bit on one side.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 12 of 46, by LeFlash
It is socketed, trust me! The "pins"are so wide underside because of the springs inside
Reply 13 of 46, by H3nrik V!
Yeah, looks like "tulip" sockets, like the pins in these: https://www.google.com/url?sa=i&source=images … 554297438945669
Reply 14 of 46, by uscleo
You guys are right. I got a knife under there and gently pried it off! Now to get an AMD5x86 upgrade! Thanks guys!!
Reply 15 of 46, by LeFlash
Remember that this socket gives your CPU 5V! For 3.3V CPUs, you need an adapter with built in regulator!
When your 5x86 is compatible with 5V (e.g. contains regulator), everything is fine.
Reply 16 of 46, by uscleo
No worries. I sprung for an upgrade kit with the voltage regulator. It’s going to be interesting to see how fast I can get my compaq 386! 😎
Reply 17 of 46, by uscleo
Ok so I replaced the 486sx with a 486dx2 and I couldn’t get the compaq to POST, just ram check then blinking cursor but then nothing. The 5x86 with the 5v to 3v adapter was worse, the screen didn’t even turn on when I flicked the power switch.
Anyone have any suggestions on what might be compatable with this Kingston board (and perhaps also with my compaq 386?) it’s one of the first 386’s so I’m not sure if that has anything to do with it, or is it just the Kingston board not playing nice.
Any suggestions? Maybe I could go the route of overclocking the 486sx, but I’d like to try other means before playing with replacing the 33.333 Crystal. Do you guys think a Pentium overdrive would work as they are advertised and replacements for a 486sx on the box. Maybe something from cyrix or AMD? What were the most compatable upgrade options for a 486sx?
Reply 18 of 46, by LeFlash
Do you have an 486dx (33 or 40mhz) for testing?
I can only imagine that there's a problem with the built-in FPU in the DX or later processors.
Reply 19 of 46, by uscleo
I doubt that’s the problem as if you read here this Kingston “486 Now” came in dx and sx flavours and I bet the board would be the same for both, and they swapped out the processors. http://ps-2.kev009.com/ohlandl/CPU/Kingston_486Now.pdf
