First post, by suntac
Hi friends!
This code is fully compatible with all revisions of Sound Blaster 2.0, including those with the CT1336A bus interface chip.
My investment into the hardware has already returned via eBay, and thus I am hereby releasing these GAL equations into the public domain.
Also, let me congratulate to scorp who has also resolved one of the issues with CT1336A all by himself.
Cheers,
Rado
66.56 KiB
C/MS Upgrade Equations
CHIP SB20CMS 16V8
; Author: suntac at Vogons (Rado M.)
; Version: 2.0
; Date: 22nd December 2018
; Description: * fixes issues with the OPL2 and the digital part when used together with the CT1336A BIC
; * improves handling of the reset signal
; * resolves D-type flip-flop timing hazard
; * adds support for disabling the ISA IOCHRDY functionality
/cms1_or_opl=1 /cms2_or_x=2 /cms=3 u14_q2=4 /wr=5 /reset=6 _gnd7=7 _gnd8=8 /ena_iochrdy=9 gnd=10
/u5_u8_dtack=11 nc12=12 iochrdy=13 /u17_cs=14 /u8_cs=15 /u5_cs=16 /u14_set2=17
u14_d2=18 u14_clk2=19 vcc=20
EQUATIONS
; note that pins 7, 8 and 9 are tied to gnd on the PAL socket
; cms1_or_opl = 1 for addresses 2X0h, 2X8h and 388h
; cms2_or_x = 1 for addresses 2X2h and 2X8h
; cms = 1 for addresses 2X0h and 2X2h
; 2X0h = cms * cms1_or_opl
; 2X2h = cms * cms2_or_x
; 2X8h & 388h = /cms * cms1_or_opl
; CMSOFF jumper bridges /cms1_or_opl and /u17_cs (pin 14)
; alternative 1 - default for most boards with CT1336 and CT1336A
u5_cs = cms * cms1_or_opl * /reset ; CS for first SAA1099P (2X0h-2X1h)
u8_cs = cms * cms2_or_x * /reset ; CS for second SAA1099P (2X2h-2X3h)
; alternative 2 - use only for rare boards with grounded pins 1 of U5/U8
;u5_cs = wr * cms * cms1_or_opl * /reset ; CS for first SAA1099P (2X0h-2X1h)
;u8_cs = wr * cms * cms2_or_x * /reset ; CS for second SAA1099P (2X2h-2X3h)
u17_cs = /u5_u8_dtack * /cms * cms1_or_opl * /reset ; CS for YM3812
/u14_d2 = cms * cms1_or_opl + cms * cms2_or_x ; 74LS74.D[2]
u14_clk2 = wr ; 74LS74.CLK[2]
u14_set2 = u5_u8_dtack + reset ; 74LS74.SET[2]
iochrdy.oe = /u14_q2 * ena_iochrdy * /reset
iochrdy = gnd ; IOCHRDY tristated
Reply 1 of 42, by keropi
Thanks for sharing Rado! Excellent work !
In my book you deserved all that ebay support and more!
Reply 3 of 42, by badmojo
+1
Well done solving the problem in the first place and now sharing your hard work with the community 😎
Reply 4 of 42, by HanJammer
I've tried older PAL 'code' (the one incompatible with CT1336A) and this one - but no success.
I converted equations to JED file using EQN2JED. Burned GAL16V8, installed in my CT1350B.
When I start the computer - it will beep like no video card is present and screen is full of colorful cr*p.
Same behaviour in both my CT1350Bs (Rev4 and Rev2) with both PAL 'codes'.
PAL was programmed with TL866II (older 'code' was encrypted while the newer - not encrypted).
It has to be connected to PAL itself - with PAL removed (not touching SAAs or CMSOFF jumper) everything works fine.
Any suggestions?
Reply 6 of 42, by HanJammer
suntac wrote:
Was the CMSOFF jumper removed when the GAL was in its socket?
What do you mean by 'encrypted' code?
Yeah, jumper was removed. It doesn't really matter if jumper is on or off - it won't boot when GAL is in it's socket.
Encrypted mode:
86.75 KiB
Apparently when I will leave it checked - programmer will no longer be able to read from the GAL (for verification etc) - when I uncheck it - it will verify the chip with no problems.
Reply 7 of 42, by BloodyCactus
try different GAL brand. Some programmers like Lattice more than NatSemi etc, some like National.. Often trying different brand helps! (sounds crazy, but its true)
Reply 8 of 42, by HanJammer
The ones I have are Lattice GAL16V8-15LP... Does it matter if it's -15LP or -20LNC or -25QB1 - because those are any other I can source quickly enough...
Reply 9 of 42, by suntac
The old free equations should work with all card revisions. The only problem would be with the FM and the digital part on cards with CT1336A. My equations work also with all card revisions and without that problem.
Many Chinese vendors sell GAL16V8B remarked as GAL16V8D. Professional chip programmers perform such checks, but I am not sure whether yours does too. You may try choosing GAL16V8B instead of GAL16V8.
I have positive experience with Lattice GAL16V8B and with Atmel ATF16V8CZ chips.
Reply 10 of 42, by suntac
I see no reason why -25 shouldn't work too.
You may send me the .JED file you created and I will test it in my setup.
Reply 11 of 42, by HanJammer
JED file: https://mega.nz/#!hYEihSAY!fcyhoVGlhlSLmES_Nn … BASQydeDKQOjkh0
I will try burning GAL16V8B.
Reply 12 of 42, by suntac
HanJammer wrote:
The .JED file is OK.
Btw, I've slightly updated the code for u5_cs and u8_cs in my first post, but that shouldn't have any effect in your case.
Reply 14 of 42, by HanJammer
suntac wrote:
There must be some issue with your programmer, its settings or the chip type used.
Programmer settings are OK (all other chips I program - like EPROMS - work fine).
Only settings I can change for GAL are Programming voltage (set to 16V) and Encryption (I don't know if I should leave it enabled or disable it, but in two previous attempts it didn't matter - result was the same).
Reply 15 of 42, by suntac
My programmer, an old Elnec BeeProg, works correctly.
However, I must program the device (GAL or ATF) in two passes. First time without security fuse and finally just to set the fuse, without prior erasing. Now, when the equations are free, there is no point in protecting the GALs against reading.
Reply 16 of 42, by keropi
I have programmed many GALs with a TL866CS - without changing any of it's defaults and unless the IC is damaged then it works.
My guess is that HanJammer has some bad ICs ...
Reply 17 of 42, by HanJammer
ICs in the programmer?
Well, it's a new unit, and works without any problems with EPROMs…
Edit: Also I lied - there are additional options to set during programming "CODE Memory" and "LOCK Bit" - whatever it means… I'm leaving them on default (enabled)...
10.33 KiB
Also I didn't expected GALs tro be reprogrammable (I thought they are OTP)… so I will play with them some more tomorrow...
Reply 18 of 42, by HanJammer
Good news! Setting programmer to GAL16V8B solved the problem! Chips I have are marked as Lattice GAL16V8 BTW...
So CMS now works like charm on my SB2.0.
Thanks for your great work!
