Reply 40 of 54, by spiroyster
Intel486dx33 wrote:
Cool stuff Peoples.
Anyone have an SGI Visual 3xx ?
I presume you mean Visual Workstation 320?
... why yes I do! And the 540 (bigger brother of the Cobalt VW line) 😎
929.42 KiB
From left to right:
AAlchemy 8232 SPP (Case only 😒), Nexxus 4800 cluster (8 nodes in single case! Conroes I think), SGI 320 (Dual P3 500 Mhz) and the SGI 540 (Quad Xeon 900Mhz).
The Quantum3D is a 4U case, so that gives an idea of the size of the 540 and Nexxus! Nexxus has to be dismantled to move it (medium-iron).
Reply 41 of 54, by looking4awayout
Now, I don't know if this is rare, rarest, unobtanium or uncommon or what, but I suppose I could consider this one the most uncommon computer components I have and use on my system. It's a Logitech Series/2, from 1987. Apparently, it's the first third party PS/2 mouse ever released on market and the first PS/2 mouse ever made by Logitech. Aesthetically looking it's just a C7 with two buttons instead of three, but back when I bought it, it was the only one on Ebay, I had to import it from the States. Haven't seen another one ever since. Works as it should, but I have replaced the original lightweight crappy black ball with a rubber-coated steel one, and tracks way, way better. Notice the "Patent Pending" writing on the sticker on the rear...
My Retro Daily Driver: Pentium !!!-S 1.7GHz | 3GB PC166 ECC SDRAM | Geforce 6800 Ultra 256MB | 128GB Lite-On SSD + 500GB WD Blue SSD | ESS Allegro PCI | Windows XP Professional SP3
Reply 42 of 54, by Intel486dx33
spiroyster wrote:
I presume you mean Visual Workstation 320? […]
Intel486dx33 wrote:
Cool stuff Peoples.
The attachment sgi3205408232spnexxus.jpg is no longer available
From left to right:
Wow! Nice.
540, Do you mean it has 4 Xeon CPU's ? What speed ?
What graphics cards does it have ?
That 540 must be LOUD !
Is the 320 loud too ?
I had a Dual Xeon HP z800 and it was LOUD !
My Mac Pro 2012 with the same dual Xeon CPU's was NOT to loud however.
I found these photos on the internet. But they are low resolution.
It would be nice to see some high resolution photos.
    451.9 KiB
    58.2 KiB
    10.97 KiB
    209.2 KiB
Reply 44 of 54, by Tetrium
x0zm_ wrote:
https://i.imgur.com/fiVyI5sl.jpg […]
AOpen AX6BC Pro II "Black Limited" - Japanese edition of the "Millennium Edition" board. Very few were ever made.
I wasn't aware this board even existed. I did know about the "AX34 Pro II", which is also a black PCBed board.
Several manufacturers experimented with different PCB colors in that era. Even a pink one 😜. It does make things a bit more interesting.
Anyway, except for my Cyrix 5x86 and maybe that IBM ActionMedia II board (which is more of an oddity perhaps), I probably don't have a lot of really very rare hardware laying around?
Well ok, I do have a couple CPU ES and even an Intel confidential Slot 1 board with 3 RDRAM slots instead of 2 (yes it worked and was unstable regardless of what I tried 🤣). Perhaps some 30p 16MB SIMMs?
I do have a Voodoo 3 3000 PCI with SGRAM?
My apologies, no pics. My stuff is packed up for now. Will change before the end of the year though 😀
My retro rigs (old topic)
Report spammers here!
Reply 45 of 54, by luckybob
From left to right:
That 540 makes me...
I have a quad p2 in a boring beige box. nothing as fancy looking at that SGI iron.
Reply 46 of 54, by x0zm_
Intel486dx33 wrote:
@xozm
That Aopen Motherboard is really sweet.
What case are you going to put it in ?
It'll be a surprise, if certain companies get back to me in time and agreements happen as discussed. 🤣
Reply 47 of 54, by oeuvre
luckybob wrote:
That 540 makes me... https://slm-assets0.secondlife.com/assets/15266181/lightbox/mostmoist.jpg […]
From left to right:
Reply 50 of 54, by Intel486dx33
Dell 433/L ( 486 )
Reply 51 of 54, by spiroyster
Yep, 4 x SL4XY (PIII Xeons @ 900Mhz). 2Gb ram (maxed as much as it can be!).
It doesn't, both the 320 and 540 use SGI's Cobalt graphics chipset. It's integrated into the system, takes bespoke RAM modules (prone to dying) and allows you to assign as much ram to vram as you want. Also, since it is integrated, it can copy (blit) buffers to and from GL instantaneously which makes it good for video (textures) and absolutely excels absolutely 2D performance (image manipulation etc). I used to show it off by loading massive NASA jpgs (90mb jpegs!) and being able to smoothly and effortlessly drag them and crop/paste them.
It is fully GL 1.2 compliant although 3D is CPU limited and not quite as good as it's nVidia contemporaries after about a year on market so didn't fair so well. Also the entire design team for Cobalt was 'let go' slightly before, or during launch. Well done SGI 😒
It's like late 90's workstation loud, so not quiet, but not like server farm loud. Of course it is a workstation and designed for such. Volume wasn't top priority in those days.
Not as loud, but you know when it is on 😉.
Will do next time I drag it out. As you can see it needs a clean. 🤣
Reply 52 of 54, by StaffelGuard1917
IBM PC 5150
i8088/4.77/640kb ram/EGA/ISA8->CF/joystick port card
    431.73 KiB
Reply 53 of 54, by StaffelGuard1917
Kaypro 10 Z-80A/4mhz/64kb ram/10mb HDD MFM/390kb FDD/ Cp/m 2.2f OS (1983)
it has even three games on it - Catchum, Ladder and Aliens - Pacman, Donkey Kong and Space Invaders clones. yep all in pseudo-graphics)
Also Pascal, C, Assembler and other languages are available for CP/m - so I hope to study it and write more gmaes for it in C.
    441.73 KiB
Reply 54 of 54, by SpectriaForce
It's not rare, neither the IBM PC 5150 (unless it is an early revision). The EGA monitor on top of the IBM PC is probably the really rare item 😉
