First post, by kikendo
So I am having this problem:
https://imgur.com/a/dF0BLJU
All those lines on the right weren't there before as far as I remember.
What do you think could cause it? This wasn't happening before.
It only happens with VESA modes. I have UNIVBE loaded.
Is the card bad (RAM?)? Motherboard? But all other modes seem to work just fine!
Reply 1 of 9, by rasz_pl
vesa modes or one and the same vesa mode? looks like bad ram chip (partially) as it takes <1/7 of the screen
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 2 of 9, by retardware
Is the card bad?
It is UNIVBE which is bad.
Back then decades ago I had to tell people this often.
Getting a VBE driver that is written for the specific card/chip always solved these problems.
I think there is a S3 VBE driver around, will check myself later today, as I also installed a Virge (DX) in my retro computer.
Reply 3 of 9, by kikendo
Well after further inspection I can say not all VESA modes, I tried the "unicentr" app and I didn't see this happen. It only happened with these emulators using weirder modes (like 384x257 which apparently are planar modes).
Well I was using it before without problems. But yeah if you have a DOS S3 app, let me know. I think I used to have one back in the day for my Diamond S3-based card.
Reply 4 of 9, by Jo22
Getting a VBE driver that is written for the specific card/chip always solved these problems..
My experience was similar here. I never got an 8/16-Bit ISA card like, for example, a WD90C31 card to work with UNIVBE.
Using the manufacturer VBE driver worked for me fuirst time. For Trio32/64 and Virge, S3VBE20 (S3 VBE/Core 2.0) should o the job.
However, I'd rather replace the VGA-BIOS with something VBE2.x compatible.
From what I learned with the Trios, some BIOSses came with VBE 1.2, some with VBE 2.x.
Gratefuly, they are all interchangeable across different boards often, as long as the S3 chip matches.
Reply 5 of 9, by kikendo
Now I also notice that I get brightness changes when I do stuff like click the mouse. Could this card need recapping?
I can also hear noise via the soundcard when this happens.
Damnit. Playing music also makes the brightness flicker. This is messed up.
Reply 7 of 9, by zyga64
Use S3VBEFix and vertical lines will disappear...
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 8 of 9, by kikendo
rasz_pl wrote:
you might want to check your psu, and capacitors on the motherboard 5V rail
The PSU is OK, but the motherboard, maybe it has cap issues, even though I was sold it as " capacitors checked OK".
How should I check the caps, if they show no obvious sign of being faulty? (No bulging, no acid).
Edit:
So I checked the PSU at a floppy/hd power plug, I get 4.76V on the 5V line, which sounds normal to me?
On the motherboard, I probed the USB port, and I get 4.67V 😒
Reply 9 of 9, by kikendo
Champ! That problem did disappear with this software. Thanks!
However I still have the other problem. ANd I notice, it only happens in Windows... 😢 😠
