First post, by Deksor
Greetings,
I have two IBM XT 5160 motherboards that do not POST. My plan is to currently fix one of them.
So the board I'm willing to fix is powering up (it had a bad cap on the -12V, which shouldn't prevent the board from POSTing if missing, and before that cap went bad, I remember the board doing the same thing), but nothing really happens (no beeps, nothing on the screen, etc)
I'm using a cheap realtek VGA video card to test the motherboard (I've tested it before in 8bit isa slots in other computers so I know it works in 8 bit mode). The settings on the switchbank are correct (all RAM banks are filled so I've set the matching settings, I've set the video mode to EGA/VGA, no 8087 and no continuous POST). Both motherboards are the 256-640KB revision.
I've also attempted to swap any removable chips between both motherboards, the board I'm trying to revive behaves the same.
By the way, there is some life in that board : when I put my POST card in it, I see the numbers moving really fast (I think it's an incrementing value. It's really going too fast to read anything, but I think I see the pattern of a hex number being incremented), then it stops on "0F" shortly, then it countinues, and then it stops on "0F" again, and this time it's stays there forever.
I've also attempted to swap the BIOS chips from one board to another, but still nothing. I've also tried to reduce onboard ram virtually by setting fewer banks on the swichbank, but no change in the behavior.
So I guess some chip is dead in there, but I have no idea what chip could be the cause of this.
alternative
Reply 1 of 10, by HanJammer
POST cards are good for nothing in XTs (that's what I learned recently 😀 ). I would start with swapping BIOS ROM with Supersoft Landmark Diagnostic ROM - but for this to work you will need MDA or CGA card (it won't work on VGA). There's also Ruud's diagnostic rom but I prefer Landmark's one.
http://www.minuszerodegrees.net/supersoft_lan … dmark%20ROM.htm
Check out my YouTube channel the "Rusty Bits"
Reply 2 of 10, by Deksor
Ah, that is kinda annoying as I only have one compatible CRT ... Oh well I'll try that, thanks a lot ! (Actually SOME vga card might work apparently)
alternative
Reply 3 of 10, by jesolo
Have you tried swopping out the RAM chips in bank 0 with those in bank 1? Take note that, since you have a 256-640KB revision of the 5160 motherboard, you can only swop RAM chips between bank 0 & bank 1.
A failure of any of the chips in bank 0 results in what appears to be a 'dead' motherboard - more info here: http://www.minuszerodegrees.net/5160/problems … #bank_0_failure
I can also highly recommend this site for further information and the forums on http://www.vcfed.org, particularly this section: http://www.vcfed.org/forum/forumdisplay.php?2 … -PCs-and-Clones.
Hopefully, your problems are not as severe as my one motherboard, which had some RAM delay line issue (I never managed to resolve the problem completely).
Reply 4 of 10, by Deksor
Well ...
1.21 MiB
890.58 KiB
It works flawlessly ... (floppy read is showing an error because I didn't plug any floppy drive)
It seems like that board acts dead if I use my VGA card (which I've tested on a 8 bit ISA slot), but with MDA it's perfectly fine !
Problem solved I belive ? (Thanks again for your help 😁)
Well ... like I mentionned, I have two boards, the other one still acts dead (nothing happens even on the POST card), no beeps, nothing with the landmark ROM, nothing with the BIOS.
I may have a clue though, I think that the fan spins quite fast with that one, so there may be some more bad caps in there (on the +5V I think)
alternative
Reply 5 of 10, by Predator99
Already mentioned this in HanJammers XT repair thread, but thats exactly what I observe on my (working) XT-boards. So at least you can see something is going on.
To my surprise, when you send data to port 80h on an XT with debug.exe, it is not displayed on the POST-card. This works on 286 up. Dont have an explanation for this yet...
Nice monitor btw 😉
Reply 6 of 10, by Deksor
Thanks, but unfortunately it's not working very well, the picture itself is ok, but the colors are brighter on the left than on the right and they fade to the right. And R, G, B aren't affected the same. They're all affected, but red seems to be the most affected color.
I have no idea what does this nor how could-I fix that.
alternative
Reply 8 of 10, by Deksor
Hard to say since things tend to be more blurry on crts when it's too bright. But I'd say (though I'm not sure) that this is the brightness.
alternative
Reply 9 of 10, by Deunan
Likely not a HV issue then. Although any CRT monitor repair should start with re-soldering each and every pin on the flyback transformer.
If geometry looks OK-ish then it's probably a capacitor issue somewhere in the cathode drivers. Shorts and weak tubes typically have a single color going missing or the whole picture brightness is affected. Replace all electrolytic capacitors on the neck board, if that doesn't help, the main board as well. Don't skip the low value ones (1-10uF or so), these too dry out and cause all kinds of problems.
Reply 10 of 10, by HanJammer
Deksor wrote:
It seems like that board acts dead if I use my VGA card (which I've tested on a 8 bit ISA slot), but with MDA it's perfectly fin […]
It may be BIOS related. My XT motherboard (not the one from the repair thread) worked fine with VGA and dip switches set to 'mono' monitor. Anyway unless you want it to be 100% original I would replace the BIOS with Super PC / Turbo XT BIOS which adds plenty of "modern" features like boot from HDD and support for HD floppies (even the 2,88MB ones).
Grab it here: http://www.phatcode.net/downloads.php?id=101
Probably it will also fix the VGA issue (also if this VGA is 16-bit make sure it works in 8-bit mode - on Trident cards you will have jumpers for that).
