First post, by _Roffe_
I found this card in a IBM Model 80 - 111
And i have not for sure figured out what model it is or where to find drivers for it..
Only numbers i get any hits on is 5019578-01..
1.67 MiB
1.81 MiB
With that number I found a ebay item that looks just like my card. Mine say 5019578-01 C01 the ebay item is 5019578-01 D01, and the Digital sticker has some more info(A09-DE212), dont know if this is exact same as mine should have been. My card has the number DE212 on the back panel tho..
This is the Sticker from the Ebay item, mine just say Digital
237.55 KiB
More pics (My card)
1.88 MiB
1.81 MiB
Reply 1 of 8, by _Roffe_
hmm, that looks a little odd, is that RJ-45? 😀
And the DE212
1.59 MiB
Reply 3 of 8, by _Roffe_
PC Hoarder Patrol wrote:
Maybe the manual will help to trace the drivers
http://decdoc.itsx.net/dec94mds/de212omb.pdf
Thanks! It made me a bit wiser at least 😀
Reply 4 of 8, by eisapc
You could ask in comp.sys.ibm.ps2.hardware newsgroup. If the driver is availiable anywhere, somebody there will know.
Despite tons of MCA equipment in my basement, I dont own this board, so I am not sure if I have any drivers.
eisapc
Reply 5 of 8, by _Roffe_
eisapc
Thanks, that place looks like it have a lot of questions, then i might even be answers 😀
Iam going to trow a question in there to and hope something bites 😀
Reply 6 of 8, by PC Hoarder Patrol
Some additional info on the card / drivers
http://www.walshcomptech.com/ps2/digital-ew.htm
also the two adf files linked at the top of this page are still available on archive.org.
https://web.archive.org/web/20020808224906/ht … page2/_6def.adf
https://web.archive.org/web/20001005234326/ht … page2/_628d.adf
Reply 7 of 8, by _Roffe_
Some additional info on the card / drivers […]
Thanks alot!
that http://www.walshcomptech.com was very useful!
I have played around with wayoldmachine a bit, I always do the .com.tw try on any manufacturer, and as it say Digital made in taiwan on the card, that was the first i did 😀 But it only links me to stupid compaq.com.tw in taiwanese 😀 This is to old for waybackmachine even, and bad luck compaq bought digital or how the story goes...
Reply 8 of 8, by PC Hoarder Patrol
Glad those links were some use to you.
In fact the NICs in the EtherWORKS MC range are referenced on the main Compaq support menu pages on Waybackmachine, but unfortunately they point to old Digital URLs, in this case http://www.networks.digital.com/dr/nics/, and like other Digital links, they've been specifically excluded from the archive.
