Old Firefox ssl certificates override
Getting old software/games running on older hardware.
Postby Jens » 2019-5-10 @ 17:09
Hello, i noticed that i wrote to much. So, here my edited request in (hopefully clearer) "compact mode":
- I'm experimenting with old FFes (legacy, prior v53). My favorite is 'Light', a lean FF49. Due to out-dated certs i get errors for most https-sites. Sure i can make exceptions for each, but that's unnerving and expires within 3 months.
Is there a kill-switch in about:config to override the cert-validation = make FF treat every https site like unencrypted http = accept any outdated or non-existing cert as valid by default? If not, how can i import a to-date cert8.db? Copy & paste from more recent FFs does'nt work, maybe there are other files to consider? Matching tips i found in www are obsolete and do'nt work.
Pls, i do'nt want to start a security-discussion. I'm not dumbo & aware of the risks when surfing to unverified sites, even exotic ones like https://google.com.
Jens
Re: Old browsers ssl certificates
Postby BushLin » 2019-5-10 @ 17:38
Ignoring the obvious joke of asking whether you can vs. whether you should...
If you go to about:config and filter by security.ssl you will find many settings which need changing to bypass very useful security features to reach your goal.
Seriously though, I wouldn't browse the web with XP in 2019, you may not care if it becomes infected/compromised but anything it shares a network with is then at risk too and if you can flash firmware, attackers can too. You don't need to visit a shady site, drive by attacks are served up by adverts in unexpected places. If you must use XP for browsing, do it with uBlock Origin or uMatrix as at least a filter when letting the wild west into your home.
If you don't want to spend $50 on a more recent device then a minimal Linux install would be far more secure for your trusty old museum piece.
BushLin
Postby Jens » 2019-5-10 @ 18:11
Thank you, but i try to stay online with this computer until i am forced into a retirement-home = the year 2050 a.D. (at least!). If i have to be on the safe side, i'm using my Android-mobile instead.
Edit: My original request was a bit vague, sorry for this. I modified the 1st entry.
Jens
Postby jmarsh » 2019-5-10 @ 19:12
Anybody can make a self-signed certificate, getting one that is signed by a trusted authority that is recognised by most browsers takes a lot more work (requiring identity verification and such).
Old browsers won't be able to support the newest encryption modes/key exchange algorithms enforced by some sites so blindly accepting certificates as valid won't help much.
jmarsh
Re: Old Firefox ssl certificates override
Postby Jens » 2019-5-13 @ 11:23
Thank you, but... I do'nt want to create a cert, i want to get rid of them. Encryption = ssl/tsl is not the point. Even IE8 can decrypt https. My concern is to make a usable browser want to do so without asking me all the time for confirmations...
Jens
Postby Jens » 2019-5-14 @ 11:06
In case somebody wants to know: On
https://github.com/JustOff/ca-archive/releases
you will find an 44MB .xpi archive containing a clean catalogue incl. direct install-links to thousands of outdated-Firefox extensions. I found a superb add-on for my needs at the first push.
Jens
Postby rasz_pl » 2019-5-14 @ 12:56
what you want is ssl stripping proxy
https://www.youtube.com/watch?v=MFol6IMbZ7Y
servers nowadays not only require ssl, but also force new crypto not available in old browsers, not that I would encourage you to use outdated browsers in any shape or form (you are one bad link from remote exploit and having your old system loaded up with malware/cryptolockers)
rasz_pl
Postby Jens » 2019-5-14 @ 17:24
@rasz_pl: 1st time i hear about ssl stripping. Thank you for teaching me something new! But far too heavy for my, i'm only an ambitious surfer, so i shall keep my hands off. I just tried the FF-addon "Skip cert error 0.4" which auto-checks all the "make an exception?" buttons when a https-site offers an invalid cert. Works fine, that will do for now. The addon is from the above mentioned .xpi collection, really great for every FF-user who can't find anymore working extensions, access to *all* .xpi that were on mozilla from 2004 to 2018, highly recommended!
Jens
Postby rasz_pl » 2019-5-15 @ 06:11
installing random extensions from random collections is another great way to get your system full of viruses, not to mention stolen credentials
rasz_pl
Return to Software
Who is online
