First post, by Intel486dx33
I want to put togeather a basic DOS 6.22 boot diskette with cdrom support.
I don’t want the ALL-Disks Boot diskette as it has too much stuff.
I want to make my own and keep it simple.
What files should I have?
I have IDE drives and IDE CDROM and floppy dives too.
I need files like:
MSCDEX
Cdrom.sys
Atapicd.sys
Depart
Format
Edit
Emm386
Etc...
Can someone post an example of a good Autoexec.bat and Config.sys ?
Reply 2 of 4, by zyga64
Something like this...
config.sys
device=himem.sys /testmem:off
dos=high,umb
devicehigh=emm386.exe RAM
devicehigh=cdrom.sys /d:CD001
autoexec.bat
lh mscdex.exe /d:CD001
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 3 of 4, by brostenen
Create one from Win98.... (format a /s)
Then add the basic stuff like format.exe, attrib.exe and so on from the windows installation it self.
You need to edit autoexec.bat and config.sys manually.
It will give you the exact same options as MS-Dos 6.22, yet the procedure is the exact same as Win98.
Else you can open autoexec.bat and config.sys from the Win98 bootdisk, then copy the lines,
then change disk and open the autoexec.bat or config.sys (without closing edit) and paste the lines.
Finally copy whatever files/drivers/tsr's you need from one disk to the other.
That is how I make CD-Rom support on my Dos6.22 boot disks.
Reply 4 of 4, by SirNickity
Create a bootable disk with format /s. Every time you run into a situation and don't have the util you need, copy it to your disk. What I need isn't what you need, and vice versa.
For me, it's CD stuff, SCSI drivers for the couple chipsets I use, himem sys format edit attrib move fdisk deltree, pkunzip.
