First post, by LeFlash
- Member
Hello,
i got some new goteks and tried to flash them with flashfloppy as i did with older models. The host-systems can't read the floppy images with the Flashfloppy-firmware. The original Gotek SW works, although i cannot flash it back.
The PCB looks 1:1 identical. I tried several goteks now and have the same issue with everyone.
I also reflashed my older drive and it works. Jumpers are set correct.
Flashfloppy firmware works but the host just can't access the floppy. 🙁
Any ideas? Has gotek changed something in the latest batch?
