First post, by Deksor
Hi folks !
I've had this nice little 486 laptop with a 486DX2-40MHz and 20MB of RAM since few month, but I was never able to use it because it was missing the HDD caddy and the floppy disk drive is dead. Recently, I stumbled onto a nearly NOS HDD for the LTE 5000 (which uses the same caddy)
1.23 MiB
Yesterday, I installed MS-DOS 6.22, Windows 3.11 for workgroups, the drivers, and etc.
Since the floppy drive is dead, there is no easy way to put data on this laptop (the way I did was to use another 90's laptop and transfert with floppy disks ... That's not very fun to do), so I thought that maybe I can use a PCMCIA ethernet card.
Like this one perhaps ? (By the way, I know it works, I've been using it for a long time in my pentium laptops)
1.37 MiB
1.08 MiB
The computer boots normally, then when some DOS driver for the PCMCIA starts, the computer makes a beep, meaning the card gets detected I think, and the BIOS setup in Windows (yeah compaq made the bios setup of that computer specifically for Windows) confirms it :
1.95 MiB
So after knowing the card was communicating properly with the computer, I tried to install these drivers http://vogonsdrivers.com/getfile.php?fileid=1348&menustate=0 as well as the 32 bit TCP IP network stack.
But there is a problem ; the computer crashes when starting on this step
1.63 MiB
This happens when C:\WINDOWS\NET START is executed in autoexec.bat (Also, this gets shown wether the card is actually in the computer or not)
alternative
Reply 1 of 6, by Deksor
(sorry, had to make a second post due to the attachment limit)
Here are my Config.sys and autoexec.bat files
1.93 MiB
1.92 MiB
1.9 MiB
What could be the cause of this ? Wrong drivers ? Something off in the startup files ?
Can anyone help me ? 😁
alternative
Reply 3 of 6, by Deksor
I can but my goal is to get the nic working. Lpt is too slow and bulky for me. I also have a parallel zip drive, but then again, too slow and bulky for me.
alternative
Reply 4 of 6, by rmay635703
I have a laptop ide drive adapter and dump a canned dos/windows 3.1x installation image on the drive from my tweeter with all the typical software I like using ready to go already installed
Only thing I need to do after that is do the video driver
Also I have your exact laptop but upgraded with a 75mhz processor and fully expanded I put my generic 40gb laptop drive in it when I want to use it and take the drive out when I move onto a different laptop
Reply 5 of 6, by lolo799
Try the drivers for your exact card, available from https://socket3.wordpress.com/downloads/drivers/
or those https://downloadcenter.intel.com/en/download/3235
Reply 6 of 6, by Deksor
Thank you very much ! I'll try that this week end
alternative
