Reply 280 of 346, by chrismeyer6
makechu wrote on 2022-11-06, 22:02:So, I went and bough a non-raid KT7A with not much thinking. Just to confirm, the revision number is in the sticker next to the […]
Just to confirm, the revision number is in the sticker next to the BIOS ROM? At least on my board, there was a random bunch of numbers there, with V1.3 at the end of it, so I assume this is version 1.3 board. At the bottom of the ISA-connector, there was just a sticker with text "KT7A-TIK005412", a round sticker with a "D" on it, and sticker with stamps on it, presumably related to quality assurance.Next thing that caught my eye here is that it is mentioned that the version 1.3 KT7A uses a different firmware from earlier boards, but if I look at http://abit.ws/page/en/motherboard/motherboar … &pPRODINFO=BIOS , there is no mention of different BIOSes for different board versions, and the kt7a9.exe seems to be the newest BIOS update file. So, is this actually compatible with the 1.3 board?
If not, does somebody have the latest original unmodified bios image somewhere? At least I could not find it here on the forums after some amount of searching...
I'll try to patch the KT7A (non-RAID) BIOS file myself with the CPU microcode patches, and for enabling software CPU multiplier switching, if I just first know for sure which is actually the latest official BIOS file for the non-RAID V1.3 board.I was a bit surprised that there may be some slowdowns / other issues caused by using more than 512 MB of RAM on the KT7A. I have had zero issues with using 1 GB on QDI Kinetiz 7E, which is also KT133A based, and I have all the timings set the tightest the BIOS menu allows. However, I have not done benchmark testing against using just 512 MB. Based on the 3DMark01 & 03 scores I looked up in Google, performance was pretty close what to expect from equivalent RAM, GPU & CPU combo.
Additionally, I am using 2 TB IDE hard drives (note, using a drive that emulates 4096 byte physical sectors as 512 for maximum compatibility) with Windows 98 SE on Kinetiz 7E, whereas it is said here that the ABIT-KT7A only supports LBA 28, which may limit the max. size to 137 GB. I've previously also used Quadro4 750 XGL (closely equivalent to Geforce 4 Ti 4400, but with twice the ROPs and slightly slower memory clock) with zero issues on Kinetiz 7E, but here I see that some Geforce 4 Ti models may have some issues with KT7A, which also does not sound very good to me... Currently, I have the Kinetiz 7E paired with a 256 MB Geforce 6800.
Considering these things, now I think that if I patched the BIOS on Kinetiz 7E with the CPU microcode updates and for enabling software CPU multiplier switching, I actually think the Kinetiz 7E clearly beats the KT7A for my use cases, as I have zero interest in overclocking any old hardware (although I am using a slightly overclocked mobile Barton 2600+ @ 2266 MHz on the Kinetiz 7E 😀. But, I will still do a full recap on the KT7A and see what it can do with a mobile Barton 2500+, that I have waiting on the shelf.
At least for me, stability is number one when it comes to using these things for reminiscing the good old times. And also, I mean, why keep beating up good old horses with some crazy overclocking during their retirement years while they are not dead yet :pFinally, THROTTLE.EXE with ACPI works pretty great in DOS with the Kinetiz 7E, although I need to remember to always disable it if before turning off the computer or it hangs with a black screen. As a side note; compared to the two K6-3+ setups I also have, I find the KT133A setup to be much better with way less issues, even for DOS gaming, than either of the K6-3 platforms with VIA MVP3 (Epox MVP3C2) or Ali AladdinV (Asus P5A-B rev. 1.04) chipsets.
I run 1.5 gigs with my KT7A-raid and the performance is spot on in XP Pro. You could have a issue with your ram settings in the bios or possibly a weird ram stick.
