Jane's Fighters Anthology
Getting old Windows games working.
Postby Frednoeyes » 2019-6-09 @ 22:42
Greetings All! I've been trying to get Jane's Fighters Anthology working on Windows 7, but it's been uncooperative. Running it in regular Win 95 compatibility mode makes the menus laggy and causes the cutscenes to crash. Trying it with dgVoodoo 2 caused the game to lock up hard. Any suggestions?
Frednoeyes
Re: Jane's Fighters Anthology
Postby mrpenguinb » 2019-6-13 @ 08:10
Disable visual themes if you can. Also disable desktop composition and transparency, instead of using Win 98 compatibility mode.
User avatar
mrpenguinb
Postby Frednoeyes » 2019-6-14 @ 04:32
Alas, I'm afraid that I already had all of that stuff disabled already, so not my solution.
Frednoeyes
Postby filipetolhuizen » 2019-6-14 @ 20:54
Try my custom fix. You'll need MS Application Compatibility Toolkit to use it.
fa.rar
(953 Bytes) Downloaded 15 times
User avatar
filipetolhuizen
Postby Carrera » 2019-6-18 @ 12:53
What does this fix do exactly?
Carrera
Postby Frednoeyes » 2019-6-18 @ 21:19
Not really sure if the fix isn't working for me, or if I'm too stupid to implement it correctly, no luck still either way.
Running FA in anything other than Win 95\98 Compatibility mode causes a crash.
Thanks though.
Frednoeyes
Postby Kreshna Aryaguna Nurzaman » 2019-6-19 @ 15:16
Say no to online installer.
Kreshna Aryaguna Nurzaman.
User avatar
Postby filipetolhuizen » 2019-6-22 @ 15:38
Carrera wrote:What does this fix do exactly?
Basically it sets thread affinity to 1 core, avoiding crashes, while still keeping the mouse movement smooth (jerkyness is a side effect of single thread affinity). It also sets the desktop resolution to 640x480x8 to avoid crashes between missions. I may have set some useless compatibility flags as well, but since it ran stable as a rock, I decided not to remove anything.
Frednoeyes wrote:Not really sure if the fix isn't working for me, or if I'm too stupid to implement it correctly, no luck still either way.
Thanks though.
You need Microsoft Application Compatibility Toolkit to be able to use the fix. Just open the fix with MS ACT and install it. Anyway, the official patch 1.02F is highly recommended. And for the colours to show correclty, either Directdraw Compatibility Tool or a batch file to stop explorer.exe while in the game is needed.
User avatar
filipetolhuizen
Postby Deffnator » 2019-7-11 @ 20:30
Jane's FA with the official patch and nocd by Jfkpeterson forums doesnt work well with Dgvoodoo2, it suffers from black screen stuttering bugs
ATF on the Other hand, has no problems with it
Deffnator
Return to Windows
Who is online
Users browsing this forum: No registered users and 5 guests
