Another PS/2 Mouse ISA (ISA8) card adapter
Reply 260 of 278, by maxtherabbit
aries-mu wrote on 2023-11-12, 11:27:
Also, I was wondering, what if on such old PCs one actually connects the PS/2 mouse (instead of the keyboard) to the 5-DIN connector via a simple 5-DIN to PS/2 adapter
would not work at all
Reply 262 of 278, by aries-mu
maxtherabbit wrote on 2023-11-12, 13:57:
too bad!
copper wrote on 2023-11-12, 15:14:
Upping this. Any news?
Apologies, I still intend to do this but got very busy with work for a while.
Oh no need to apologize. Take all the time you need. I understand what it means when life gets (has it ever been different?) crazy insane... just wanted to know if it was still planned...
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Reply 264 of 278, by analog_programmer
rasz_pl wrote on 2023-09-26, 14:16:
This ISA card is two things. PS2 to serial converter, and a Serial 8250 ISA card. It looks great and is a neatly designed all in […]
This ISA card is two things. PS2 to serial converter, and a Serial 8250 ISA card. It looks great and is a neatly designed all in one package. But if you arent after aesthetics and just want a working mouse and already have one serial port available in your computer then $10 will get you there without dedicated card:
https://github.com/LimeProgramming/USB-serial-mouse-adapter for USB mice
USB to Serial Mouse using the Pi Pico! https://dosreloaded.de/forum/thread/5044-usb- … -pico/?pageNo=1
Or as you already have a COM1/2 equipped old mobo/system, just try the one and only user-sensible "blaster"-ish project form this YT-channel: https://www.youtube.com/watch?v=elgyVhlFi6k
P.S. I'm not a fan of this channel and actually I don't find any sense in all the horizontal/vertical/diagonal/north-east/etc. battery "blasters" and so on, but the USB-2-serial mouse seems interesting project (if it works). And how can it be more than remarkable project, if the channel's owner has more than remarkable no-flux-soldering skills... complete tragedy.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 267 of 278, by feipoa
copper wrote on 2024-01-20, 02:28:
feipoa wrote on 2024-01-20, 02:13:
Did anyone eventually pickup the ISA serial emulator card builds?
Hoping to start working on it this week but don't know how long it will take.
Do you have the 3D printed 90-degree brackets and the hole-stamped slot cover?
Reply 269 of 278, by Sphere478
calamitylime made a pcb based rear bracket
Sphere's PCB projects.
Reply 270 of 278, by copper
Sphere478 wrote on 2024-01-21, 01:40:
No need for that, I think the options are:
  • Put a motherboard-style PS2 header on the card, and include an off-the-shelf bracket with PS2 port and cable. The bracket would not be attached to the card PCB, but maybe this is useful for some people with limited rear panel space.
  • Have new metal brackets fabricated; I have a recommendation for a place to do it, but don't know cost or minimum quantity yet
Thoughts?
Reply 271 of 278, by AndrewBoy
I'm interested in this project. I have plenty of rigs that cannot handle ps2 and plan to use a KVM switch. Do you know if this ps2 converter would work with an ATEN KVM switch? I need at least 8 PCB-s, SMD is not a problem. I'm in Hungary, so sending the final products to Europe should not cost more than 10 EUR. Does anyone care to join me, and share the gerbers, bom, and firmware?
Reply 272 of 278, by Yoghoo
AndrewBoy wrote on 2024-05-08, 05:26:
Don't think this project is open source so no gerber/firmware etc are available as far as I know. I believe because of sanctions for Russia it's not available atm.
This is working great with an ATEN KVM as I have several myself (and would like more 😀). Do not buy a replacement like the PS2TOSERIAL from Serdashop. It does not work and no replies/help for this issue are given on this forum when I posted about it in that dedicated topic.
Reply 273 of 278, by Sphere478
Yoghoo wrote on 2024-05-08, 08:12:
Re: Another PS/2 Mouse ISA (ISA8) card adapter
Reply 275 of 278, by Sphere478
snipe3687 wrote on 2024-05-08, 14:57:
are there gerber files for this posted somewhere? seems pretty useful.
Reply above yours
Reply 276 of 278, by snipe3687
Sphere478 wrote on 2024-05-08, 16:05:
Reply above yours
ughh sorry, I clearly didn't read the whole thread!
Much appreciated!
Reply 277 of 278, by Sphere478
No worries 😀
