Reply 20 of 30, by Jo22
By the way, does somebody know what it needs to run GEOS programs off a floppy ?
I mean, is it enough to copy a *.Geo file somewhere to the floppy or is it required to store it in a special folder structure ?
And are special fonts or libraries required ?
Reply 21 of 30, by Caluser2000
Depends on the program. The programs from the TVA Katter archive should run without issues. Other programs will need supporting file such as the help files that are kept in a particular directory. The program will moan if it needs extra files.
Reply 22 of 30, by Jo22
Thanks! Do you know of a simple program that runs on GEOS 1.x or 2.x ?
It can be anything, the simpler the better. 😀
Edit: In essence, I only like to test if the StarWriter's GEOS
will execute external programs that aren't stored inside the ROM..
Once that works, I'll do further testing. 😀
Reply 23 of 30, by Caluser2000
Geos 1.* programs wont load at all but docs created by them may be uploaded but converted to geos2 format. Here's a link with some small programs. Try the 2/3 ones and maybe 4. http://www.geos-infobase.de/DOWNLOAD.HTM#GEOS Like under the Spiele section. There is a couple of games there.
Reply 24 of 30, by Jo22
Thanks!
Quick update - I tried the games so far.
Blockout (BLOCKOUT.GEO) was the closest to work.
The others complained about missing system files (which ?)
or were too large to fit on a single floppy (Blockgame, for example).
Could it be that the homebrew programs were written in R-Basic / NBasic ?
If so, I guess I have to find out how to copy the BASIC runtime to the floppy.
Edit: I also tried some utilities. The only two program thats worked were "Webmagik" and "Eurokonverter 2.0".
Well, their installers, installd.geo/webminst.geo, at least. Their icons were also shown correctly.
Also, when deleting the program files, it warned about them being "PC GEOS" files.
So now we do at least know that this thing is indeed running some form of PC GEOS! 😀
Edit: Pictures added.
Edit: Picture with the deletion warning added.
    238.03 KiB
    156.71 KiB
    574.04 KiB
    135.73 KiB
    119.26 KiB
Reply 25 of 30, by Jo22
Update.
There's a program called "Universal Installer" which seems to run.
- Could it be that the other programs with the .00x suffix do need it ?
If so, it could be tricky to run programs on the StarWriter.
There's no hard disk space I could install these programs to. 🙁
Edit: Pictures of Uni Installer added.
The error message appeared after "installing" a text editor and clicking "File" in the menu.
    328.02 KiB
    593.88 KiB
Reply 26 of 30, by Caluser2000
*.00* files are support files or documents. As you mentioned above *.geo files are actual programs designed to run on PCGeos.
It should be mentioned IBM had software based on PCGeos called EduQuest SchoolView. https://sites.google.com/site/iclasschoolview … schoolview-plus
Reply 27 of 30, by Jo22
Cool, looks really neat! I've also "video documented" my tries in the mean time.. https://youtu.be/PvclU59d-mo
Once I figure out how to transfer/run the programs without installation (maybe installing on a real GEOS first), I'll contiune testing. 😀
Reply 28 of 30, by Caluser2000
Was going through my floppy stash and came across a disk of files I used to add to GeoWorks 2.* Files came from the original TVA Katter web site and other sites I found scouring the interweb using dailup back in '98 or so. Might be useful. Its a disk image of a 1.4meg disk so you'll need RewWright to create the disk once you unpack it. Looks like I picked up quite a few fonts for Geos over the years as well. As I have two 1.4meg disks worth by the looks. If you want them just sing out. They were freely available from on old Yahoo PC Geos group iirc.
Geos2up.7z
770.55 KiB
10 downloads
Reply 29 of 30, by Jo22
Sure! Sounds interesting. I'll try the attachment next night (temperatures are really high in my place currently). 😅
Reply 30 of 30, by Caluser2000
Ok here you go:
GEOFONT1.EXE
1.31 MiB
8 downloads
GEOFONT2.EXE
1.25 MiB
9 downloads
Just put the *.exe in the c:\geos\fonts directory, run it to extract the font files and delete the *.exe file. Fonts will then be available for all applications. Haven't tested it but they may even be able to be used in PC Geos 1.*
