First post, by JSO
Sometimes the drive reads the floppies, sometimes not, I've cleaned the heads with alcohol...
But...
It may reads the data, but cannot boots from a system floppy.
The floppies are working great to my floppy drive on my modern PC.
So is a hardware issue?
Is fixable, or just the drive is dying?
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
Reply 1 of 5, by BushLin
Try a different cable, some disks which have been heavily used can be more sensitive also.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 2 of 5, by JSO
I have that in my mind...
These Sony and and 3M floppies are 25 years old...
Also, I waiting for a brand new dual floppy cable to add a 5.25" 1.2 MB floppy drive to the system.
Reply 3 of 5, by Jo22
Depends. Are you using a normal ISA FDC card, an Multi-I/O card with FDC and IDE or an on-board FDC controller ? Is the PC a 286/386/486 or a 586 ?
Reply 4 of 5, by JSO
It's a VLB Multi I/O card with UMC chipset. The LCS-6924, dated on 1995...
Reply 5 of 5, by Caluser2000
Could be head alighment by the sounds of it. A replacement should be easy enough to get.
