MP-32 : Pi based MT32, GM, ... module
Reply 20 of 103, by dreamblaster
Some progress, FX1 hardware is ready (still working on the firmware)
soundcard with usb audio streaming and effects processing possibility.
It will be perfect for usage in MP-32 and other projects too
maybe i should make a separate thread for FX1
1.3 MiB
Thanks for your support !
Reply 21 of 103, by hard1k
Awesome, my friend!
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 22 of 103, by appiah4
dreamblaster wrote on 2020-03-22, 17:31:
Some progress, FX1 hardware is ready (still working on the firmware) soundcard with usb audio streaming and effects processing p […]
So cool!
Reply 23 of 103, by Thermalwrong
I'm keen to know more about it, it's the first time I've seen it mentioned. I assume it's a soundcard / midi player for the pi?
Reply 24 of 103, by dreamblaster
Thermalwrong wrote on 2020-03-24, 16:49:
it is a soundcard + midi interface for the pi (and any other platform that supports usb audio class and midi class... ))
Reply 25 of 103, by arthur071169
Hi, I just stumbled upon this page after looking at various other suggestions for MunT emulation on laptops, spare pcs etc.
I have used Dosbox successfully with MT32, but having just taken ownership of a P2 win98se real PC, I was looking for suggestions that are more compact for use with the retro PC running real DOS. This looks great, and I would also.lkke to.sign up.for a unit as and when reordering happens. Is there a mail notification I can subscribe to for alerts on this project, or is it just a case of visiting this website/board every now and then?
Re the display orientation,I also think that on the side and not the top is nicer as I would have the unit on the shelf next to the monitor, but I will take whatever is available!
Many thanks for starting this project, it is exactly what us 'real hardware' DOS users need!
Reply 26 of 103, by arthur071169
I absolutely need one of these for my DOS pc!
dreamblaster wrote on 2019-06-23, 18:43:
Hi, here are some photos of a project I've been working on for a while : MP-32 = MIDI PI 32 It still needs more work, but since […]
Hi,
It still needs more work, but since a few months it is on hold. I started to reconsider the idea.
So I thought today, I just show it as it is, and hear your feedback : Maybe it will give some inspiration
for when i pick it up again :
Generally this project is :
- PI3+ connected to a PCB with buttons + LCD, support for encoder dial (not in enclosure yet), for running synth emulators (MUNT, fluidsynth,...),
- an plug on USB sound card (new design, not yet ready, dream based) with an excellent CODEC, as audio+midi interface, also allowing line in mixing and effects
- headphone output with headphone amp
- a nice enclosure
Connectors on the rear :
main PCB:
- 3.5mm line in
- 3.5mm line out
- 3.5mm headphone out (digital volume control through menu)
- MIDI IN DIN connector
- optional MIDI THRU (not yet)
sound card :
- USB device for the soundcard (not yet) -> will need small cable to pi USB host... (i don't like that)
pi :
- USB host connections
- ethernet
Connectors on the side :
pi :
- HDMI
- 5V power (micro USB)
- original pi audio out (not used normally)
Connectors on the front :
pi :
- micro SD card slot for soundbanks, settings, software,...
That's it for now..
Reply 28 of 103, by dreamblaster
Progress on FX1 firmware, i made a separate thread for it : FX1 : USB audio, midi interface, and live multi effects
Reply 29 of 103, by dreamblaster
A friend helped me, by 3d designing a new enclosure that looks more like MT32 : see renders :
1015.1 KiB
433.15 KiB
439.05 KiB
Also refactoring the pcb for this, to avoid the need for additional FX1 board
but adding button and pot pcb instead, for 'rack mount' design instead of top operated.
Reply 30 of 103, by appiah4
Serge you have so many projects I want, just release a few so that I can give you my money already 😁 That enclosure looks FANTASTIC.
Reply 31 of 103, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes! That looks great
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 32 of 103, by Salient
dreamblaster wrote on 2020-08-01, 09:31:
THIS..... is what I want!
Reply 33 of 103, by arthur071169
Looks fantastic. Will the display provide all the info the full sized MT32 does ? Channels, text info for Sierra online games etc?
The design is better than I hoped for at this time.
Great work to all involved.
Reply 34 of 103, by dreamblaster
arthur071169 wrote on 2020-08-01, 14:09:
will try
Reply 35 of 103, by arthur071169
Giddy to have this as an affordable option to a 'real' MT32. Even though dosbox offers MUNT, I would like to have this sat next to my PII and CRT and get a mostly real world setup when I use emulation via a laptop. The comedy messages that appear when playing Sierra games don't exist on screen with MUNT so silly as it is, I want one if these mostly for aesthetics.
Reply 36 of 103, by dreamblaster
updated 3d design :
now with full mt32 button panel
    442.3 KiB
    1.07 MiB
