First post, by pan069
I have this OPTi-495SLC board and I'm trying to configure it for my Intel 386DX-33 CPU (PGA). However, looking at the Stason jumper settings, it kinda seems to give me conflicting instructions (or I'm just reading it wrong which could very well be the case).
https://stason.org/TULARC/pc/motherboards/U/U … 86WB-CACHE.html
Under the section "80386 AND CX80486DLC CPU CONFIGURATION", for 33Mhz it list the following:
Speed JP6    JP7    JP8  JP9        JP22
33MHz closed closed open pins 2 & 3 open
But then for "CPU SPEED CONFIGURATION" is says:
CPU Type  JP6   JP7   JP8     JP9         JP22
33MHz open open closed pins 1 & 2 open
Which is basically the opposite...
I also found this alternative manual, but it doesn't seems to cover the 386DX-PGA installation 🙁
http://www.elhvb.com/webhq/models/486vlb2/opti495slc.htm
Thoughts welcome...
Reply 1 of 6, by Caluser2000
Looks like the first listing is for the 386 socket side(486DLCs are basicly 386s with some L1 cache) and the second proper 486 side, notice the 25 and 50i match and the 33 and 66i match.
Reply 2 of 6, by pan069
Ah, OK. So you're saying that when the CPU type is 486 that the Mhz is selected under the "CPU SPEED CONFIGURATION" and that it doesn't apply to 386 config. That makes sense.
That means that in my case under the "80386 AND CX80486DLC CPU CONFIGURATION" I select the 33Mhz and under "CPU TYPE SELECT" I select the PGA option. The "CPU SPEED CONFIGURATION" selection is than irrelevant for my config.
One more question though, the board has 2 VLB slots. I assume these only work in 486 mode?
Reply 3 of 6, by Caluser2000
According to this brochure vlb peripherals are available the both 386s and 486s
DXSLC_Brochure_1992.pdf
973.03 KiB
41 downloads
It's a pretty neat mobo.
Reply 4 of 6, by alvaro84
I have used a 386 and VLB in a similar board, at once.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 6 of 6, by Caluser2000
No worries mate. Have fun.
