First post, by MKT_Gundam
This mobo looks like a OEM version of the VB 601
The only problem i cant find the manual to check the front panel header for LEDs and buttons. No indication in the board.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 2 of 5, by MKT_Gundam
Warlord wrote:
http://www.edstrainsonline.com/support/pdf/vb601.pdf […]
The front a panel headewr of Vb-609 is different
Reply 3 of 5, by PC Hoarder Patrol
Does this look like your board layout?
549.23 KiB
If so, this might help with the status panel pinout
Front panel connectors:-
Pins 5&6 (closest to the DIP switch) are the on/off. Pins 3&4 appear to be the power led, and 1&2 appear to be the HDD led.
http://www.motherboards.org/forums/viewtopic. … a092f23#p150848
Reply 4 of 5, by MKT_Gundam
PC Hoarder Patrol wrote:
Does this look like your board layout? […]
This model!
I tried that link but all links are dead.
At least i find the header to power on the mobo.
Reply 5 of 5, by MKT_Gundam
Sadly the mobo dont want start. No even beeps.
