First post, by RiP
- Member
make sure the scsi cable is terminated. Check the drive ID jumpers and that its not sharing same ID with the controller, floppy or other device on the cable.
Try connecting just the drive to the controller with no floppy attached as well.
wrote:make sure the scsi cable is terminated. Check the drive ID jumpers and that its not sharing same ID with the controller, floppy or other device on the cable.
Thank you, just terminated the HDD and ST02 detected it 😎
