FIC 486-GVT not POSTing
Reply 21 of 26, by Maxx1234
majestyk wrote on 2022-01-29, 19:50:
You could try the PAL for GVT-2 for a start:
FIC 486-GVT-2 missing PAL
Thank you for your prompt response!
I will try it and report back with the result.
Reply 22 of 26, by Maxx1234
Unfortunately it does not work.
No POST beeps, no display signal.
My PC Analyzer Diagnostic Card shows the FF AMI BIOS code - that means probably that the motherboard is trying to boot.
This means that either the JEDEC file is not appropriate, or the mobo has another unidentified fault.
Please (anyone) let me know if the appropriate JEDEC file becomes available.
In any case, thank you again.
Reply 23 of 26, by Maxx1234
Found the U2 GAL16V8B and Award BIOS from another board.
Will test and report back.
    NM27C512@DIP28.BIN.zip
    41.17 KiB
    42 downloads
    GAL16V8B.JED.zip
    426 Bytes
    35 downloads
Reply 25 of 26, by Maxx1234
computerguy08 wrote on 2022-03-15, 12:07:
Here's the GAL dump from my 486-GVT-2 board (in case it helps).
https://www.ultimateretro.net/en/motherboards/2380#downloads
Thank you for your interest.
If my efforts fail with the new bios & jedec file, I will try yours...
Best regards.
Reply 26 of 26, by Maxx1234
I finally found a GAL dump from a working 486-GVT and it works!
