Reply 20 of 44, by ODwilly
- l33t
https://www.ebay.com/itm/New-StarTech-ATXPOW4 … dcAAOSwa2tcnO6u here is the exact version of the 450watt I had, down to the fan design and stickers. Although it is a 400 instead, should be pretty overkill for your needs. It uses some mid grade Teapo caps, which you might want to check for failure. Just happened to stumble across it in my email notifications that I had marked for ebay keywords.
