First post, by PcBytes
Built a custom Socket 370 rig inside a IBM Netvista 6578 case 🤣
PSU: Hipro 155W
GPU: Palit ATI Radeon 7500 64MB AGP
Mobo: EPoX EP-3VCM (VIA694X)
ODD: NEC DVD-RW
RAM: 384MB PC133
CPU: Intel Pentium 3 1GHz
HDD: IBM/Hitachi Deskstar 20GB (will probably replace with a Samsung drive because its making an unbearable sound, even if it's working fine.)
NIC: Realtek RTL8139D
Case: IBM Netvista 6578 case
Interestingly, everything fit like it was from factory. Just the built in speaker inside the system needed converting to a 3.5mm jack.
I'll probably install Windows ME and then 98lite 4.7 over it to have the system run blazing fast. Kind of a "MiniME" machine.
Reply 2 of 2, by PcBytes
Yeah, pretty sturdy! Also love the modularity of the case. Just pull up the cages and you're done.
    986.3 KiB
    Desktop. Have been debating whether I should run 98lite or leave it be like that. Oh, and also got KernelEX while at it.
    389.1 KiB
    Award BIOS. There was always something fascinating about seeing "Apollo" come up on a POST screen for me.
    1.13 MiB
    Scandisk before SETUP
    1.03 MiB
    Stealth! So stealth nobody will suspect anything.
    156.92 KiB
    During test fits. Note that the green AGP card was a FX5200, not the current Radeon 7500.
