First post, by stalk3r
- Member
Does anyone have this kind of card? I am looking for its jumper settings, but the only thing I found is that it was made by Protac: https://fccid.io/J4UVGA415BFT4
J9 is for 8-bit mode (all closed = 8 bit, all open = 16 bit). No idea about the rest, there's normally not that much on a VGA card you need to configure.
wrote:J9 is for 8-bit mode (all closed = 8 bit, all open = 16 bit). No idea about the rest, there's normally not that much on a VGA card you need to configure.
I suspect this has a jumper for WS 0/1 , but way too much combinations there
wrote:Quick Google: www.s100computers.com/My%20System%20Pag ... Manual.pdf
Thanks! This means that it doesn't have one for WS 0/1 (JP2 is missing)
No, ISA mandates a default wait-state timer that can be overridden if the card is fast enough. In case others are lurking and aren't aware, most Trident boards I've seen adhere to a reference design WRT the jumpers, so the list above will apply to a lot of different cards.
I got a significant boost on my 8900D by enabling 0WS and FIFO.
wrote:I got a significant boost on my 8900D by enabling 0WS and FIFO.
I have tested this quickly with a 8900CL-B (similar to 8900D in terms of performance) which has a soldered jumper for WS:
Vidspeed WS1 - 3869
Vidspeed WS0 - 5140
(32% increase)
LM60 WS1 - 3870
LM60 WS0 - 5120
(32% increase)
3DBench WS1 - 15.8
3DBench WS0 - 15.1
(4.6% increase)
It gives a boost indeed.
I have tried 5424 and 5429 isa vga cards that have the 0ws jumper - it never worked reliably for me... Benchmarks were ok but games or win3 would just crash... The boost is indeed considerable if the system is stable
wrote:I have tried 5424 and 5429 isa vga cards that have the 0ws jumper - it never worked reliably for me... Benchmarks were ok but games or win3 would just crash... The boost is indeed considerable if the system is stable
I ran Doom timedemo several times with 0ws on the Trident, not a single crash. Haven't tried win3.1 though
wrote:win3 would just crash
So, it runs normally then? 😉
wrote:wrote:win3 would just crash
Yup. And in three (3) different ways, too!
- That's why 3.1 came out so quickly. 😁
If Win3 was a game, each type would correspond to a difficulty level. 😉
Enhanced = HARD
Standard = Normal
Real = Easy
stalk3r wrote on 2019-08-06, 12:19:I have tested this quickly with a 8900CL-B (similar to 8900D in terms of performance) which has a soldered jumper for WS: […]
Vidspeed WS1 - 3869
Vidspeed WS0 - 5140
(32% increase)LM60 WS1 - 3870
LM60 WS0 - 5120
(32% increase)3DBench WS1 - 15.8
3DBench WS0 - 15.1
(4.6% increase)It gives a boost indeed.
I have a TVGA 9000C with FIFO and ZeroWS enabled. Have been tested with Vidspeed before and after enabling 0WS. The result showed a 21% boost (640x480-256):
Vidspeed WS1 - 2767
Vidspeed WS0 - 3352
BTW, I soldered a jumper to J5. There seemed to be no difference if I shorted them. By examining the PCB myself, it seems to be Memory Clock Frequency related. Anyone knows what it does actually?
