Reply 20 of 30, by feipoa
Let me know when the CPU arrives. You need to set the CPU voltage, type, adjust BIOS settings, and remove the SRAM TAG chip (its in a socket).
Reply 22 of 30, by Vipersan
Note to self ..
"I must stop spending"
..but I just spotted an ISA creative AWE64 CT4500 at a good price...
Well I _had_ to didn't I
Better FM synth compatibility for DOS games.
Please someone help me stop this addiction..
Reply 23 of 30, by Vipersan
Currently having fun loading up the D Drive with DOS games while waiting for the K6 III cpu..
So far I've installed the majority of my Floppy game collection without issue ..
Leisure suit Larry 1 - 2 and 3
Lost letters of Sherlock Holmes.
Epic Pinball ..Cyborgirl and Lucky Strike
Manic Mansion
Rise of the Robots
System Shock
Star Wars - X wing - B wing & Imperial Persuit
And My first CD game 'Under a Killing Moon'
So ..roughly a third of drive D: used so far ..and a huge number of more recent CD games to go.
Some of those Floppy games were recovered with my KF/SCP floppy station...and I thought were lost forever.
rgds
VS
Reply 25 of 30, by Vipersan
feipoa wrote:
I find installing software the most painful part of the setup process.
You are not wrong there buddy..
I had moved on to installing a few Disc based games ..
Managed to install Tex Murphy games UAKM and Pandora ..in DOS ..but when I got to Overseer..
NADA..
Turns out it wont run with a voodoo card ...Glide incompatibility ?
Anyway much digging later I found a glide wrapper for win98 at http://dege.freeweb.hu/dgVoodoo/dgVoodoo.html
Which allows it to run ...
In truth I was amazed this was needed ..but a very useful bit of software indeed.
I have never actually played Overseer ..so a new /old game for me.
It has sat on my display shelf unplayed for years..
cest la vie
I did initially try it with DirectX 9c (previously installed) ..but it didn't recognise it ..so had to retrofit DirectX 7 as well..
Reply 26 of 30, by Vipersan
Hi Feipoa ..
My cpu has arrived .
A couple of pins need straightening ...but hopefully this is just cosmetic.
So ..before I try and fit it..I'll wait for a list of changes I need to make..plus those photos of course.
rgds
VS
Reply 27 of 30, by Vipersan
Not perfect but close enough..
The IO shield blanks from China are a bit thin and so difficult to work with drills and files..and somehow I managed to get the PS2 hole centre about 1 mm out...
but still ..it will do the job.
If I had some D type punches I'd also mount the ports on there ..but soddit ...too much much work with hand tools.
rgds
VS
    311.38 KiB
    314.13 KiB
Reply 28 of 30, by Vipersan
Before I make any further changes I thought it worth running Phils DOSBENCH on the system as a record.
So ..running the overkill voodoo 5500 card with a 233 Pentium MMX.
Chris's bench score :-
73.7
44.2FPS
L1 cache 16kb
L2 cache 512kb
Main mem speed 123.1mbs
cpu clocked at 234.2 mhz
Doom Demo 2134 gametics in 930 realtics
rgds
VS
