First post, by tegrady
Is there an adapter available that will convert a standard 3.5" floppy drive cable connector to a 5.25" floppy drive cable connector?
I am asking because I have found an adapter that converts a 3.5" floppy drive to USB via an internal connection to a USB 2.0 header. I want to do the same thing with a 5.25" floppy drive, but, of course, the connector for the 5.25" floppy is not compatible with this USB adapter.
Therefore, I am looking to see if there is a adapter that will connect between the standard 3.5" floppy cable and the 5.25" floppy drive.
I did a quick search, but could not find anything.
Thanks in advance.
    56.5 KiB
Reply 1 of 14, by Deksor
Actually I'm more intested by the 3.5" to USB adapter rather than 3.5" to 5"1/4 ^^
(By the way, there are many floppy cables that provide both connectors)
alternative
Reply 2 of 14, by JudgeMonroe
It's likely that the USB adapter *is* the cable, i.e., it does not provide an opportunity to use your own cable.
Reply 3 of 14, by tegrady
I updated my original post to include a picture of the USB adapter. I need something to convert the 34-pin "cable" shown to allow it to plug into a 5.25" floppy drive. Thanks.
Reply 4 of 14, by PC Hoarder Patrol
Wouldn't be hard to make your own - all you'd need is a short length of old floppy cable with a suitable 34 pin female edge connector at one end and a 34-pin male IDC ribbon connector at the other.
Reply 5 of 14, by Deksor
Well sure this might not be something I can make myself, but perhaps you can buy it new ?
alternative
Reply 7 of 14, by Mister Xiado
Seems like a missed opportunity, if it doesn't play ball with 5.25" drives. Of course, I used to use a 5.25" floppy drive with my Windows 7 system, but its motherboard still had a floppy connector.
15.31 KiB
Reply 8 of 14, by Merovign
1) USB 5.25" drives have existed, but they're extremely rare. ( http://www.deviceside.com/fc5025.html )
2) Generally external USB 3.5" chipsets don't support 5.25" drives, but I can't speak to this one as I haven't seen it before. So you probably won't be able to use it with a 5.25" drive.
But if you do, let us know where you got it so we can buy them out of stock!
*Too* *many* *things*!
Reply 9 of 14, by tegrady
derSammler wrote:
Such adapters do exist, but you can not connect a 5.25" disk drive via USB. It simply won't work.
Where can I find one so that I can give it a try? Thanks.
Reply 10 of 14, by thevdm
Theoretically you could create a coupler using 2.54mm header pins so you can just plug an old FDD cable into it
They can be cut down to the correct length using wire cutters and the blank pin can be pulled out with pliers, might be worth addig a couple of cable ties to hold it all together. The main question would be whether one of the USB adapters would support a 5.25 drive, I've looked at them in the past when I've thought about adding an internal 3.5" drive to my modern computer.
Gaming rig: Dell Dimension XPS T500 - PIII 500 - 288MB RAM - Voodoo3 3000 - SoundBlaster Live! Value - DVD-ROM - CD-RW - 3.5" 1.44 - 98SE & 2000 dual boot
A nostalgic pile of laptops from the late 80's to late 90s.
Reply 11 of 14, by HanJammer
I've seen adapters to connect 3,5" fdd to 5,25" fdd ribbon cable (in fact I have at least 5 of them), but the other way around - nope (it doesn't mean they don't exist of course).
Check out my YouTube channel the "Rusty Bits"
Reply 12 of 14, by Deksor
Maybe someone could make a universal USB fdd controller out of an arduino such as the arduino leonardo ? (One could push the thing even further maybe by making it a more permissive controller to backup protected games/write to Amiga/mac floppys)
alternative
Reply 13 of 14, by HanJammer
There is such controller already and it's called KryoFlux.
https://webstore.kryoflux.com/catalog/product … &products_id=28
Reply 14 of 14, by Deksor
Yeah but that one is quite expensive, I thought about a cheaper and free alternative.
Edit maybe doing this with a raspberry pi zero would be cheaper and need less low level programming ? (at least for testing proposes)
alternative
