First post, by Benedikt
Recently, I realized that there is no real replica of the Disney Sound Source, yet.
There is the thread "Reversing the Disney Sound Source", but the compatible hardware suggested therein looks quite different.
So I thought I should just give it a shot and quickly threw this together:
27.47 KiB
It's an ATtiny24 with voltage regulator and RC low-pass filter for the PWM output. The DAC in the original dongle was unfortunately a custom part.
The discrete 22kΩ resistors in the original dongle have been replaced with resistor packs, because there's not enough space in a standard enclosure.
36.02 KiB
The solder bridges connect the RESET and MISO lines in a way that should permit programming via parallel port.
30.31 KiB
What do you think? Does this make sense? Would it be fully compatible?
Reply 2 of 12, by Benedikt
Your confusion is justified. According to the programmer's guide the Sound Source uses pin 17 (C3/SELECT) as its strobe signal, presumably to avoid confusing a printer on the pass-through port.
Reply 3 of 12, by Benedikt
And this is the power supply and amplifier part:
74.57 KiB
However, I do not know some of the capacitor values nor the exact type of PNP transistors and only the one and two digit component designators are the same as on the original board.
Anything with a question mark is guesswork.
Reply 4 of 12, by SirNickity
Doesn't look like it would be too critical anyway. Q3 and Q4 are in the audio path, if I'm following the design correctly. It looks like Q1 and Q2 are a power switch for the LM386. C101 is a bulk cap for the V+ rail. C103 is a decoupling cap for the audio. 10uF should be OK for either, though either one could be fudged by a factor of 10 and would probably work fine. You'd lose bass response if you went too small, but it's not exactly a hi-fi DAC....
I've been interested in picking one of these up to fiddle with, but like a lot of retro stuff, they're going for far more than they're worth on Ebay. Best bet is definitely to RE it, and spend twice that much on manually cloning it. 😈
Reply 6 of 12, by Tiido
C6 is part of zobel network and usually is a 0.1µF film cap.
Reply 7 of 12, by Benedikt
Well, now that you say it: The data sheet does show a capacitor connected to the output with a 10Ω resistor to GND, but all the example circuits use 0.05µF.
So I guess I'll use 0.05µF, as well.
But what is C4? Some kind of filtering for the volume potentiometer, maybe? Wait! That must be part of an input high-pass.
Reply 8 of 12, by matze79
There is already a working clone 😀
shock_ already made a dss clone, now also with stereo support and switchable covox/dss/Stereo mode
and it does not require a MCU 😀
https://dosreloaded.de/forum/index.php/Attach … ovox-krams-jpg/
Reply 9 of 12, by matze79
Do you plan to add covox mode for Stereo ?
Reply 10 of 12, by Benedikt
I'm aware:
It's a lovely project, indeed, but quite far away from the real thing. Replacement dongles and amplifiers would allow people to mix and match as needed.
I don't really see how replacing a custom chip with an MCU would be a disadvantage in this case, because the MCU that can technically be programmed via parallel port sits in a parallel port dongle, already.
You therefore wouldn't even strictly need a programming adapter.
Stereo would not be possible with this approach, but I might be able to include dumb LPT DAC compatibility by programming the ATtiny to just mirror the input while the FIFO is empty.
Reply 11 of 12, by Benedikt
And this is a schematic of the power supply and amplifier part:
23.75 KiB
Thanks for your help, keropi!
Reply 12 of 12, by Benedikt
There have not been any significant modifications since the previous posts, but in case anyone wants to build e.g. the amplifier unit, the design files are now online.
