AWE64 Legacy
Reply 160 of 782, by Cyrix200+
hard1k wrote:
Guys, it's as low as on the regular SB16/AWE64/Vibra cards, not lower, not higher. <snip>
Dang you're right. The render you posted skewed the view a bit I think.
1982 to 2001
Reply 161 of 782, by The Serpent Rider
Interesting project. Looking forward to buy one, if it's affordable.
Reply 162 of 782, by tpowell.ca
Is it compatible with a Sound Blaster Pro 2.0 in Stereo for PCM sound, or is that a hardware limitation of the Creative chips?
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 163 of 782, by gdjacobs
No Creative SB16 card supports SB Pro. I think they had inherent limitations in the DSP. To do this, the EMU would likely be best used like a Goldfinch with an SB Pro chipset on the same card.
Reply 164 of 782, by hard1k
Hello guys!
We are happy to announce that the second prototype PCBs have arrived, so the tests will begin soon - we're still waiting for some components, but most of them are here already.
As you can see from the PCB and from the changelog in the first post, we've implemented most of your requests from the questionnaire. No other major changes will be made at this point, unless the current design shows some serious flaws. So, if my calculations are correct, the next PCB batch will be a production run, and it might get ready just in time for the Boxing Day. Fingers crossed!
Pictures of the current PCB for your viewing pleasure:
741.35 KiB
464.16 KiB
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 168 of 782, by hard1k
There will be at least 2 options - blank PCB and fully assembled/tested product.
However it is still too early to talk about pricing, preorders, ETA, etc.
AWE64 Legacy
Reply 169 of 782, by hard1k
...work in progress...
274.1 KiB
194.68 KiB
AWE64 Legacy
Reply 172 of 782, by stacker139
I just fell in this thread and I find this sound card integration interesting. Although it seems to me that it's too late, I'm going to make some suggestions as well:
to implement (if you would like it):
1) An internal 2-pin header for digital out
In this way you can to connect to CD_SPDIF internal header of Live & Audigy creative sound cards
I use this to internally link my Goldfinch with my audigy 2 and use the effects of the KXproject.
2) Two or three holes on the PCB to insert mini spacer to fix the wavetable addon card.
Do you have any schematic (specially on the Mpu, OPL3 and analog parts) ?
Project: SB-XXXL, Extensive Sound Cards System
Reply 174 of 782, by jaZz_KCS
brownk wrote:
I'm already half out of my mind by the expectation of nirvana this card would take me to.
hard1k, please put me in whatever list you are bookkeeping.
Ditto, this is beyond awesome. I am closely watching this project with much anticipation. Please put me on the list 😀
Reply 175 of 782, by hard1k
Thanks to all of you guys, there's no list at the moment, as soon as we start accepting pre-orders we'll let you all know by an announcement in this thread, so stay tuned and check your updates from VOGONS.
Noted, will try to implement that.
Unfortunately there won't be any new holes (yet I'm personally for those, but the rest of the team don't like to drill the PCB without some absolute need; moreover the questionnaire has proved that not many people really need those holes).
We haven't yet decided to make the schematics publicly available, but we'll think about it later.
Some new pics:
146.27 KiB
105.51 KiB
86.33 KiB
136.45 KiB
AWE64 Legacy
Reply 177 of 782, by elianda
As far as I have read this on the AWE64 Legacy the EMU8K wavetable is not available as generic MPU-401 port.
Are there any considerations to make it available as it was implemented on the Waveblaster II?
Youtube Channel
Reply 178 of 782, by hard1k
No, we're keeping it as is. First, there is not much sense in it as it would deprive the Soundfont loading capability. Second, CT8920 chip is a highly integrated one, with no datasheet available, and hiding all of the former discrete chips (including the EMU8000) inside, so we've had to treat it as a black box with no deep alteration of the original schematics.
AWE64 Legacy
Reply 179 of 782, by elianda
Ok, so having the Emu8K directly accessible through 0x620 and providing general MPU-401 access to it through e.g. a MC68K would not be possible at the same time?
And every feature beyond GM, like SF loading would require some protocol extension like other sound cards implement (e.g. SAM9407).
Youtube Channel
