First post, by ShovelKnight
Hi,
I noticed there are some motherboards that were sold in 2 versions: with a 1 Mbit BIOS chip and with a 2 Mbit BIOS chip. Usually these motherboards have some sort of later/enhanced BIOS (e.g. with 128GB HDD support) which is available only for the 2 Mbit version.
If I get such a motherboard, would it be possible to simply replace the BIOS chip? For example, I could buy an SST39SF020 or any other 5V 2 Mbit flash chip, flash it with a TL866 programmer and install it in place of the original 1 Mbit BIOS chip. Would it work?
Reply 1 of 4, by dionb
If the only difference is the BIOS size: yes.
Sometimes though the larger BIOS is related to other changes between revisions (different sound or I/O chips etc), in which case it probably won't work. But if unsure, no harm in trying - you still have your original BIOS and you can always re-flash the 2Mb EEPROM for another board if it fails. Just make sure you line up the chip correctly - only way I ever smoked a board messing with BIOS was the time I accidentally got the chip the wrong way round...
Reply 2 of 4, by ShovelKnight
Thanks a lot! Seems like it's worth trying.
Reply 3 of 4, by GigAHerZ
It is recommended that you fill the larger chip.
So if you have 2Mb chip and 1Mb ROM, put the ROM in twice: one from the beginning and one from the middle.
This protects you from the case when the upper address lines may behave in unknown way - you just don't care, if your chip is full as described.
A little about software engineering: https://byteaether.github.io/
Reply 4 of 4, by ShovelKnight
Just checked and the BIOS file is exactly 2 Mbit (262144 bytes) in size
