Reply 141 of 440, by Keatah
Seems any version past v1.81.0 doesn't properly report Core Speed on a Pentium M, stays locked at 1694MHz, when in reality it should range from 600 to 1694 depending on demand. Core VID is also unchanging. Bus Speed and Rated FSB are not even displayed. And of course any info fields for Intel ExtremeGraphics^2 are empty.
But the multiplier is properly displayed, and it changes from 6 through 17 as system demands change.
If you're interested in fixing all this I can provide screenshots or more information.
Reply 143 of 440, by agent_x007
348.11 KiB
Awesome job again, thank you 😀
Q: Will it work on D0 revision as well, or is this C0/C1 only fix ?
Reply 145 of 440, by agent_x007
Maybe it's for newer CPU-z version, but I have a request/suggestion :
I would like for CPU-z program to show uCode version CPU/MB is using (it could be add on either "CPU" or "Motherboard" tab).
Reply 146 of 440, by PC@LIVE
Hi, as soon as I can I have to try it on the old PC of my collection, I thought it only worked with win95, instead it works also with W.XP and W.7.
I tried it on my Internet PC:
HP MSI Amethyst-M 1.0 ATi Radeon Xpress 200
AMD Athlon64 X2 3800+
Bestec 300W
Corsair 4GB DDR400
HD WD 40GB SATA
S.O. W.7
I include an image.
Soon I will try on the Pentium Pro 200.
    145.24 KiB
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 147 of 440, by PC@LIVE
Bench PentiumPro 200MHz
    39.57 KiB
    38.85 KiB
    40.13 KiB
    39.1 KiB
    54.19 KiB
Reply 149 of 440, by DosFreak
Noticed this today:
http://www.os2museum.com/wp/more-about-that-s … ange-pentium-4/
A few years ago I wrote about a strange NetBurst processor with SL7HY S-spec that landed at the OS/2 Museum. After renewed reader interest I pulled it out of the closet and tested the processor again. A collection of miscellaneous notes follows.
CPU-Z today is just as clueless as it was a few years ago (no surprise), thinking it’s a Socket 604 processor and that it’s an engineering sample:
Make your games work offline
Reply 150 of 440, by aka286dos
If it's of interest. I get a BSOD with MD5 (cpuz_w9x.exe) = 0c391b3bd686147c602c6afe4429361f:
A fatal exception 0D has occurred at 0028:C1BB31C6 in VXD CVXDSAMP(01) + 000001C6.
Windows 98SE on one of these: https://www.parkytowers.me.uk/thin/hp/t5710/
Reply 151 of 440, by CuPid
@DosFreak : Thanks. ES detection is pretty straightforward tho, I guess some CPUs are wrongly marked.
@aka286dos : Thanks for the report, I'll try to fix that and will let you know.
I need a vacation.
Reply 152 of 440, by CuPid
"CPU-Z Vintage Edition" is now publically available :
https://www.cpuid.com/news/66-cpu-z-vintage-edition.html
The validation works (cvf and online), and the pages are specific to that version (not visually yet), with a special forum banner (there are some examples in my signature).
Once again I thank you all for your help so far.
I need a vacation.
Reply 153 of 440, by PiotrUU
Hi,
Ti486sxl PGA168 + ULSI FPU @ exp4349
    55.27 KiB
    208.13 KiB
    59.84 KiB
Reply 154 of 440, by CuPid
Thanks PiotrUU. I've improved things to make the detection of the SXL better, can you please give it a try and let me know ?
http://download.cpuid.com/betas/cpuz_w95.zip
Thanks 😀
I need a vacation.
Reply 155 of 440, by PiotrUU
I did some tests. Win95 did not work with cx486s (M5) and cx486dx (M6) on exp4349 !!
WIN95 with CPU cx486dx2 (M7) works.
I send results via email.
    57.99 KiB
    101.16 KiB
    58.05 KiB
    114.97 KiB
    58.63 KiB
Reply 156 of 440, by CuPid
Thank you PiotrUU.
It is indeed strange that the DX2 works and not the DX nor the S. Are you use that they are working ?
The SXL is detected as a DLC with a 16-KByte L1 😵. The cache detection routine is wrong because it is designed to detect 4-way caches, and I think the SXL uses a 8-KByte 2-way cache.
Anyway, that version should work OK on the SXL.
Also, the validation should work too, another problem was fixed on that side.
I need a vacation.
Reply 159 of 440, by Carlos S. M.
Tried CPU-Z Vintage Edition on NT 3.51 (running on a VM) with SP5, some updates and VC++ 6.0 libraries, throws an error about a missing function about OS version, but starts.
Will try some older hardware later on 9x or NT 4.
54.47 KiB
main window
39.32 KiB
bench
47.46 KiB
About window
Edit: errors found
6.08 KiB
first error
62.49 KiB
second error
