Reply 580 of 1037, by mastergamma12
Everything looks fixed. As for why this ram's at 2666 instead of 3200, thank Intel for not allowing H370 to run anything higher than 2666.
file.php?mode=view&id=90036
    1.54 MiB
    SIV_PORTA-BOX.zip
    355.33 KiB
    52 downloads
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 581 of 1037, by red-ray
mastergamma12 wrote on 2020-08-14, 14:46:
Thank you for checking things out and the RAM being limited to 2666 by the H370 makes no sense at all as the memory controller is within the CPU not the H370 PCH.
What does Menu->Help->Lock Handle report when you start the EVGA E-LEET Utility please?
Reply 582 of 1037, by Nvm1
I tested SIV on my Asus L8400L Notebook.
As far as I could see everything except the ram speed and cpu multiplier seems to match.
184mhz seems a tad optimistic for 133mhz SDram 😉
Attached screenshot and .txt file!
    128.71 KiB
    SIV_L8400L.txt
    259.11 KiB
    52 downloads
Reply 583 of 1037, by red-ray
Nvm1 wrote on 2020-08-16, 18:32:
As far as I could see everything except the ram speed and cpu multiplier seems to match. 184mhz seems a tad optimistic for 133mhz SDram
Thank you for checking out SIV and posting the results. The wonky DRAM speed is down to the FSB:DRAM 3:4 which should be FSB:DRAM 1:1.
I made some adjustments to the attached SIV32L V5.52 Tula-00 test SIV, how does it do please? I should have also improved the GPU reporting. May I have a new save file?
Reply 585 of 1037, by Nvm1
And attached the new test results!
The RAM speed and FSB:RAM seem to be correct.
The multiplier of the cpu is still a tad off (8.25 instead of 8.5) but the rest seems to be correct now!
If you have any more questions, let me know Red.
    SIV_L8400L.txt
    259.27 KiB
    47 downloads
    156.83 KiB
Reply 586 of 1037, by red-ray
Nvm1 wrote on 2020-08-17, 19:51:
Thank you, I suspect this is as good as it's going to get on Windows 9x. To get multiplier 100% correct SIV would need to read MSR 0x2A, but as Windows 9x does not have kernel mode SEHs (Structured Exception Handlers) I decided not to use MSRs on W9x. I expect it you ran NT4/W2K/WXP on the system SIV would do better.
I have now released SIV 5.52 Beta-00 which you should use rather than the test SIV.
Reply 588 of 1037, by mastergamma12
I'm going to hopefully be testing SIV on an EVGA Z370 FTW and a Biostar B350GT5 in about a few days to a week.
Reply 589 of 1037, by mastergamma12
Tested SIV on the Biostar B350GT5, the 12v voltage rail is wrong. Bios reports 12v.
file.php?mode=view&id=90484
    592.51 KiB
    SIV_BIOSTAR_B350GT5.zip
    297.03 KiB
    54 downloads
Reply 590 of 1037, by red-ray
mastergamma12 wrote on 2020-08-21, 18:03:
Thank you and so are the -70.0°C temperatures. It would be helpful to have a screen shot of what the BIOS reports, especially for the fan names.
I have adjusted the SIO mapping in the attached SIV64X 5.52 B360-03 test SIV, how do things now look please?
I had to guess the fan names, can you plug a fan into each fan header in turn and tell me if/how I need to adjust the names?
Reply 591 of 1037, by mastergamma12
red-ray wrote on 2020-08-21, 19:22:
Thank you and so are the -70.0°C temperatures. It would be helpful to have a screen shot of what the BIOS reports, especially fo […]
Here
file.php?mode=view&id=90497
file.php?mode=view&id=90498
Fan header names are correct however there is no system 3 fan header on the board.
    272.34 KiB
    665.89 KiB
    304.13 KiB
    50 downloads
Reply 592 of 1037, by red-ray
mastergamma12 wrote on 2020-08-21, 20:00:
Thank you, for I will remove SYS Fan 3 and change the name to VIN6 CPU SoC. Both the SIV reported +5 and +12 look a bit low, but it's possible they really are lower when Windows is running if the PSU is near it's limit. I suspect HWiNFO will report the same as SIV, does it?
Reply 593 of 1037, by mastergamma12
red-ray wrote on 2020-08-21, 20:25:
I think it's the psu I'm using atm, it's an old Thermaltake 430w, this board's going into a build soon and that's got a brand new Powerspec 550w 80+ bronze unit. I'll check it and report back when that's done.
Reply 594 of 1037, by mastergamma12
Did the build, HWINFO shows proper 5v and 12v.
file.php?mode=view&id=90522
As for SIV, I reinstalled windows and that siv version is umm, I didn't save it 🙁
    48.98 KiB
Reply 595 of 1037, by red-ray
mastergamma12 wrote on 2020-08-22, 06:33:
Thank you and here is the tidied version. Ideally I would like one screen shot showing both HWiNFO + SIV.
Reply 596 of 1037, by mastergamma12
red-ray wrote on 2020-08-22, 06:54:
Here
file.php?mode=view&id=90529
    1.04 MiB
    291.6 KiB
    53 downloads
Reply 598 of 1037, by mastergamma12
Ran SIV on the Z370 FTW, same thing as the Z370 Micro before you fixed it.
file.php?mode=view&id=90634
    988.65 KiB
    SIV_BORG-CUBE.zip
    380.65 KiB
    51 downloads
Reply 599 of 1037, by red-ray
mastergamma12 wrote on 2020-08-23, 21:34:
Thank you for the report and posting the files, how does the attached SIV64X 8472-03 test SIV do?
Looking at the sample counts then the SIO ones are lower than all the others, further in the save file it's reporting [Y]INUSE Wait 812 of 812 ms which usually indicates issues caused by other software.
