First post, by Lostdotfish
After some pre-purchase advice. Are PCI SATA cards supported in old Pentium chipsets? I want to be able to install and boot to SATA drives if possible (as I have a ton lying around but no old pata drives).
Are there certain chipsets that I should look for for the SATA controler?
Thank you.
Reply 1 of 5, by melbar
Better take CompactFlash to IDE adapter (CF-IDE adapter) or SD-card to IDE adapter.
You can buy them on ebay or aliexpress.
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 2 of 5, by The Serpent Rider
They usually support boot from external SCSI and IDE, so SATA will work too.
Silicon Image 3112/3114 proved to be quite reliant and compatible.
Reply 3 of 5, by matze79
But have no good 9x driver.
better get a IDE2SATA Bridge, and maybe if you want more speed a Fastrak UDMA 133 Controller.
Reply 4 of 5, by dionb
Promise TX2Plus PATA+SATA controller works fine in Win98SE, also works on PCI 2.1 motherboards (i.e. i440BX, i430TX etc).
Reply 5 of 5, by Mister Xiado
I used the CF option in my 430TX system. It feels like a bit of a waste to use a SATA adapter with it, as I don't want to have double-letter drives in my dozens of partitions. Then again, with smaller SATA drives, that wouldn't be an issue, and might be cool to have drives 20+ years newer than the motherboard.
